thinkgeo.mapsuite.portablecore.transactionresult
ThinkGeo.MapSuite.Core.TransactionResult
    • ThinkGeo.MapSuite.Core.TransactionResult
TransactionResult()
  • This is the class constructor.
  • This is the default constructor and is typically not used.
TransactionResult(Int32,Int32,Dictionary<String,String>,TransactionResultStatus)
  • totalSuccessCount
  • totalFailureCount
  • failureReasons
TotalSuccessCount
  • This property gets and sets the total number of records that we committed successfully.
  • None
TotalFailureCount
  • This property gets and sets the total number of records that we committed unsuccessfully.
  • None
  • This property gets and sets the result status of the transaction.
  • This property returns the results of the transaction. If all of the records committed fine then you get a success status. If any of the records fail then you get a failure status though some of the records may have committed.
FailureReasons
  • This property gets and sets the dictionary that contains the reasons for failure.
  • If there are failing records we suggest you add the failure reasons to this dictionary. It is also suggested that you use the FeatureId as the key of the Dictionary.
thinkgeo.mapsuite.portablecore.transactionresult.txt · Last modified: 2017/03/16 21:59 (external edit)
