This is the default constructor and is typically not used.
This method will clear all the items in AddBuffer, EditBuffer and DeleteBuffer.
This method allows you to add a shape into the buffer.
AddFeature(BaseShape,Dictionary<String,String>)
This method allows you to add a placeholder to represent a Feature to be deleted.
This does not remove a feature from the TransactionBuffer but rather it add a “to be deleted record”. In this way when the TransactionBuffer if processed we know what records need to be deleted.
This method allows you to add a Feature to be updated.
This method allows you to add a shape to be updated.
EditFeature(BaseShape,Dictionary<String,String>)
AddColumn(FeatureSourceColumn)
It is recommended that you use this dictionary for reviewing and not for adding new items. The reason is that the Add, Delete and Edit methods to various validation checks. For example if you call the DeleteFeature twice it will handle the case that you really only want to delete the record once. Another example is if you edit a record twice it will replace the existing edit with the new one.
This property gets the dictionary buffer that holds InternalFeatures to be deleted.
This property gets the dictionary buffer that holds InternalFeatures to be updated.
