thinkgeo.mapsuite.portablecore.tinygeoprecisionmode
ThinkGeo.MapSuite.Core.TinyGeoPrecisionMode
Items
AllowSplitting
  • Summary:Don't allow any splitting. In this case the precision will be low.
PreventSplitting
  • Summary:Allow splitting. In this case the precision will be high and the created TinyGeo file will usually include multi regions internally.
thinkgeo.mapsuite.portablecore.tinygeoprecisionmode.1442823625.txt.gz · Last modified: 2015/09/21 08:20 by admin
