<!– Class –> This class represents a FeatureLayer of TinyGeo File by ThinkGeo.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.FeatureLayer ThinkGeo.MapSuite.PortableCore.TinyGeoFeatureLayer
TinyGeoFeatureLayer | This is the class constructor. | ||
TinyGeoFeatureLayer | String | This is the class constructor. | |
TinyGeoFeatureLayer | String, String | This is the class constructor. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, ReturningColumnsType | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, FeatureLayer, GeographyUnit, IEnumerable<String>, String, Double, Encoding, WellKnownType | ||
![]() CreateTinyGeoFile | String, String, GeographyUnit, IEnumerable<String>, String, Double | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, IEnumerable<String>, String, Double, Encoding | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, IEnumerable<String>, Double | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, IEnumerable<String> | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, ReturningColumnsType, String, Double | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, ReturningColumnsType, String | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, ReturningColumnsType, Double | Static API to create a new TinyGeo file from an existed shape file. | |
![]() CreateTinyGeoFile | String, String, GeographyUnit, IEnumerable<String>, String | Static API to create a new TinyGeo file from an existed shape file. | |
![]() DecryptTinyGeoFile | String, String, String | Decrypt an existed encrypted TinyGeo File and save it as a new TinyGeo File. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() EncryptTinyGeoFile | String, String, String | Encrypt an existed TinyGeo File and save it as a new TinyGeo File. | |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
![]() GetOptimalPrecision | FeatureLayer, GeographyUnit, DistanceUnit, TinyGeoPrecisionMode | ||
![]() GetOptimalPrecision | String, GeographyUnit, DistanceUnit, TinyGeoPrecisionMode | ||
GetTinyGeoFileType | |||
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | TimeSpan | Layer | |
DrawingMarginPercentage | Double | FeatureLayer | This property gets and sets the extra drawing margin as a percentage around the map that draw to ensure that labeling is correct. |
DrawingQuality | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
EditTools | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
FeatureIdsToExclude | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
FeatureSource | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
HasBoundingBox | Boolean | Layer(overriden) | |
MaxRecordsToDraw | Int32 | FeatureLayer | |
Password | String | This property gets or sets the password of the TinyGeo file. | |
QueryTools | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
TinyGeoPathFileName | String | This property returns the path and file of the TinyGeo file you want to use. | |
WrappingExtent | RectangleShape | FeatureLayer | |
WrappingMode | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
ZoomLevelSet | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
IsOpenCore | Boolean | Layer(overriden) |
DrawingAttribution | DrawingAttributionLayerEventArgs | Layer | |
DrawingException | DrawingExceptionLayerEventArgs | Layer | |
DrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
DrawingProgressChanged | DrawingProgressChangedEventArgs | Layer | |
DrawingWrappingFeatures | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
DrawnAttribution | DrawnAttributionLayerEventArgs | Layer | |
DrawnException | DrawnExceptionLayerEventArgs | Layer | |
RequestedDrawing | RequestedDrawingLayerEventArgs | Layer | |
RequestingDrawing | RequestingDrawingLayerEventArgs | Layer | |
StreamLoading | StreamLoadingEventArgs | This event allows you to pass in your own stream to represent the files. |
This is the default constructor and requires you to set the properties after you create the class.
This constructor allows you to pass in a path and file name to the TinyGeo FeatureLayer.
| tinyGeoPathFileName | String<!– System.String –> |
This constructor allows you to pass in a path file name and a password to the TinyGeo FeatureLayer.
| tinyGeoPathFileName | String<!– System.String –> | |
| password | String<!– System.String –> | This parameter represents the password to the .tgeo file. |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
<!– static –> Static API to create a new TinyGeo file from an existed shape file.
| tinyGeoPathFileName | String<!– System.String –> | This parameter specifies the file name for the target TinyGeo file. |
| shapePathFileName | String<!– System.String –> | This parameter specifies the file name for the existed shape file. |
| unitOfData | GeographyUnit<!– ThinkGeo.MapSuite.PortableCore.GeographyUnit –> | This parameter specifies the Geography Unit of the data. |
| returningColumnType | ReturningColumnsType<!– ThinkGeo.MapSuite.PortableCore.ReturningColumnsType –> | This parameter specifies whether the columns info in shape file will be copied to TinyGeo file. |
<!– ThinkGeo.MapSuite.PortableCore.TinyGeoFeatureLayer –> Go Back
<!– static –>
| tinyGeoPathFilename | String<!– System.String –> | |
| featureLayer | FeatureLayer<!– ThinkGeo.MapSuite.PortableCore.FeatureLayer –> | |
| unitOfData | GeographyUnit<!– ThinkGeo.MapSuite.PortableCore.GeographyUnit –> | |
| columnNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | |
| password | String<!– System.String –> | |
| precisionInMeter | Double<!– System.Double –> | |
| shapeEncoding | Encoding<!– System.Text.Encoding –> | |
| type | WellKnownType<!– ThinkGeo.MapSuite.PortableCore.WellKnownType –> |
| columnNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | This parameter specifies the columns in shape file which will be copied to TinyGeo file. |
| password | String<!– System.String –> | This parameter spcifies the password of the target TinyGeo file. |
| precisionInMeter | Double<!– System.Double –> | This parameter spcifies in double what is the precision in Meter of the target TinyGeo file. |
| shapeEncoding | Encoding<!– System.Text.Encoding –> | This parameter specifies the encoding of the existed shape file. |
<!– static –> Decrypt an existed encrypted TinyGeo File and save it as a new TinyGeo File.
| encryptedTinyGeoPathFileName | String<!– System.String –> | This parameter specifies the file name for the source encrypted TinyGeo file. |
| decryptedTinyGeoPathFileName | String<!– System.String –> | This parameter specifies the file name for the target decrypted TinyGeo file. |
| password | String<!– System.String –> | This parameter specified the password of the source encrypted TinyGeo file. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
<!– static –> Encrypt an existed TinyGeo File and save it as a new TinyGeo File.
| unencryptedTinyGeoPathFileName | String<!– System.String –> | This parameter specifies the file name for the source unencrypted TinyGeo file. |
| encryptedTinyGeoPathFileName | String<!– System.String –> | This parameter specifies the file name for the target encrypted TinyGeo file. |
| password | String<!– System.String –> | This parameter specified the password of the target encrypted TinyGeo file. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
<!– static –>
| returningDistanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.PortableCore.DistanceUnit –> | |
| precisionMode | TinyGeoPrecisionMode<!– ThinkGeo.MapSuite.PortableCore.TinyGeoPrecisionMode –> |
<!– static –>
| shapePathFileName | String<!– System.String –> | |
| TinyGeoFileType<!– ThinkGeo.MapSuite.PortableCore.TinyGeoFileType –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
This method raises the DrawingFeatures event.
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.PortableCore.FeatureLayer –> Go Back
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This method sets up the EditTools and QueryTools objects.
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
This extra margin that we draw exists so that labels match up if they are partially cut off.
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
| DrawingQuality<!– ThinkGeo.MapSuite.PortableCore.DrawingQuality –> |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
| EditTools<!– ThinkGeo.MapSuite.PortableCore.EditTools –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
| FeatureSource<!– ThinkGeo.MapSuite.PortableCore.FeatureSource –> |
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
| QueryTools<!– ThinkGeo.MapSuite.PortableCore.QueryTools –> |
When you specify the path and file name it should be in the correct format as such however the file does not need to exists on the file system. This is to allow us to accept streams supplied by the developer at runtime. If you choose to provide a file that exists then we will attempt to use it. If we cannot find it then we will raise the SteamLoading event and allow you to supply the stream. For example you can pass in “C:\NotARealPath\File1.tgeo” which does not exists on the file system. When we raise the event for you to supply a stream we will pass to you the path and file name for you to differentiate the files.
| WrappingMode<!– ThinkGeo.MapSuite.PortableCore.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
| ZoomLevelSet<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
If you choose you can pass in your own stream to represent the file. The stream can come from a variety of places such as isolated storage, a compressed file, and encrypted stream. When the Image is finished with the stream it will dispose of it so be sure to keep this in mind when passing the stream in. If you do not pass in a alternate stream the class will attempt to load the file from the file system using the TinyGeoPathFileName property.
| Event Arguments |
| StreamLoadingEventArgs<!– ThinkGeo.MapSuite.PortableCore.StreamLoadingEventArgs –> |
