<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.ZoomLevelSet *ThinkGeo.MapSuite.PortableCore.SphericalMercatorZoomLevelSet
![]() | Object | Object | |
![]() | Object | ||
![]() ![]() | Double, ZoomLevelSet | ZoomLevelSet | ZoomToScale out, the result is greater than input |
![]() ![]() | Double, ZoomLevelSet | ZoomLevelSet | ZoomToScale in, the result is less than input |
![]() | Object | ||
![]() | RectangleShape, Double, GeographyUnit | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a screen width. |
![]() | RectangleShape, Double, GeographyUnit, Single | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a screen width. |
![]() | RectangleShape, Double, GeographyUnit, Single | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a canvas width. |
![]() | RectangleShape, Double, GeographyUnit | ZoomLevelSet | This method returns the active ZoomLevel based on an extent, a map unit and a canvas width. |
![]() | ZoomLevelSet | This method return all of the zoomLevels in the zoomLevelSet. | |
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Collection<ZoomLevel> | ZoomLevelSet | This property gets the custom zoom levels from the zoomLevelSet. |
![]() | String | ZoomLevelSet | This property gets and sets the name for the ZoomSet. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level01. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level02. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level03. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level04. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level05. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level06. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level07. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level08. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level09. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level10. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level11. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level12. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level13. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level14. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level15. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level16. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level17. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level18. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level19. |
![]() | ZoomLevel | ZoomLevelSet | This property gets the ZoomLevel for Level20. |
Name | Type | Description |
Return Type | Description |
Int32<!– System.Int32 –> |
<!– static –> ZoomToScale out, the result is greater than input
Double<!– System.Double –> |
currentScale | Double<!– System.Double –> | |
zoomLevelSet | ZoomLevelSet<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –> |
<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –> Go Back
<!– static –> ZoomToScale in, the result is less than input
Type<!– System.Type –> |
ZoomLevel<!– ThinkGeo.MapSuite.PortableCore.ZoomLevel –> | This method returns the active ZoomLevel based on an extent, a map unit and a screen width. |
extent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This parameter is a world extent. |
screenWidth | Double<!– System.Double –> | This parameter is the width of the map in pixels. |
mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.PortableCore.GeographyUnit –> | This parameter is the unit of the map. |
dpi | Single<!– System.Single –> | This parameter is the dpi of the extent. |
ZoomLevel<!– ThinkGeo.MapSuite.PortableCore.ZoomLevel –> | This method returns the active ZoomLevel based on an extent, map unit and a canvas width. |
screenWidth | Double<!– System.Double –> | This parameter is the width of the canvas in pixels. |
Collection<ZoomLevel><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.ZoomLevel} –> | This method return all of the zoomlevels in the zoomLevelSet. |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
