thinkgeo.mapsuite.portablecore.sentrequesttiledwmslayereventargs
ThinkGeo.MapSuite.Core.SentRequestTiledWmsLayerEventArgs
The event args containing the event data used by SecuredTiledWmsRasterSource.
      • ThinkGeo.MapSuite.Core.SentRequestTiledWmsLayerEventArgs
SentRequestTiledWmsLayerEventArgs()
SentRequestTiledWmsLayerEventArgs(HttpWebResponse)
  • Create an instance of SentRequestTiledWmsLayerEventArgs
  • response
    • Type:HttpWebResponse
Response
  • Gets or sets a value indicating the response from Server.
thinkgeo.mapsuite.portablecore.sentrequesttiledwmslayereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
