thinkgeo.mapsuite.portablecore.sendingrequesttiledwmslayereventargs
ThinkGeo.MapSuite.Core.SendingRequestTiledWmsLayerEventArgs
The event args containing the event data used by TiledWmsLayerEventArgs.
      • ThinkGeo.MapSuite.Core.SendingRequestTiledWmsLayerEventArgs
SendingRequestTiledWmsLayerEventArgs()
SendingRequestTiledWmsLayerEventArgs(WebRequest)
  • Create an instance of SendingRequestTiledWmsLayerEventArgs
  • webRequest
    • Type:WebRequest
WebRequest
  • The Web Request
  • Type:WebRequest
thinkgeo.mapsuite.portablecore.sendingrequesttiledwmslayereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
