<!– Class –> This class is used to draw area features.
You should use this class to draw area features. You can specify a base color and the number of colors you want based on that color to draw the interior, and you can specify an outline pen with which to draw the border. You can optionally choose to use only the outline pen or the fill brush to generate different effects.
*System.Object ThinkGeo.MapSuite.PortableCore.Style *ThinkGeo.MapSuite.PortableCore.AreaStyle ThinkGeo.MapSuite.PortableCore.QualityFamilyAreaStyle
![]() | This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually. | ||
![]() | GeoPen, GeoColor, Int32 | This is the constructor the for the class. | |
![]() | GeoPen, GeoColor, Int32, PenBrushDrawingOrder | This is the constructor the for the class. |
![]() | This method clears the cached style in the cache. | ||
![]() | Style | Create a copy of style using the deep clone process. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
![]() | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
![]() | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
![]() | GeoCanvas | Style | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object | ||
![]() | Object |
![]() | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
![]() | GeoCanvas, DrawingRectangleF | Style(overriden) | |
![]() | Object | ||
![]() | Object |
![]() | AreaStyleAdvanced | AreaStyle | This property lets you access the advanced properties of the style. |
![]() | GeoColor | This gets or sets the base color of the style. | |
![]() | Dictionary<String,AreaStyle> | This gets the cached style in the class. | |
![]() | Collection<AreaStyle> | AreaStyle | This property returns a collection of area styles, allowing you to stack multiple area styles on top of each other. |
![]() | DrawingLevel | AreaStyle | |
![]() | GeoSolidBrush | AreaStyle | This property gets and sets the solid brush you want to use to fill in the area features. |
![]() | Collection<String> | Style | |
![]() | Boolean | Style | This property gets and sets the active status of the style. |
![]() | String | Style | This property gets and set the name of the style. |
![]() | Int32 | This gets or sets the number of colors in the style. | |
![]() | GeoPen | AreaStyle | This property gets and sets the outline pen you want to use to outline the features. |
![]() | PenBrushDrawingOrder | AreaStyle | This property gets and sets the pen and brush drawing order. |
![]() | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
![]() | Single | AreaStyle | This property gets and sets the X pixel offset for drawing each feature. |
![]() | Single | AreaStyle | This property gets and sets the Y pixel offset for drawing each feature. |
Name | Type | Description |
This is the constructor for this class.
outlinePen | GeoPen<!– ThinkGeo.MapSuite.PortableCore.GeoPen –> | This parameter represents the outline pen that will be used on the style. |
baseColor | GeoColor<!– ThinkGeo.MapSuite.PortableCore.GeoColor –> | This parameter represents the base color that will be used in the class. |
numberOfColors | Int32<!– System.Int32 –> | This prameter represents how many colors will be used in the style, based on the base color. |
penBrushDrawingOrder | PenBrushDrawingOrder<!– ThinkGeo.MapSuite.PortableCore.PenBrushDrawingOrder –> | This parameter describes the PenBrushDrawingOrder that will be used when drawing the area type feature. |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.PortableCore.QualityFamilyAreaStyle –> Go Back
Style<!– ThinkGeo.MapSuite.PortableCore.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
Type<!– System.Type –> |
String<!– System.String –> |
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Return Type |
AreaStyleAdvanced<!– ThinkGeo.MapSuite.PortableCore.AreaStyleAdvanced –> |
<!– ThinkGeo.MapSuite.PortableCore.AreaStyle –> Go Back
None.
Return Type |
This gets the cached style in the class. The key of the style in the cache is feature.Id & feature.GetHashCode().
Return Type |
Dictionary<String,AreaStyle><!– System.Collections.Generic.Dictionary{System.String,ThinkGeo.MapSuite.PortableCore.AreaStyle} –> |
Using this collection, you can stack multiple area styles on top of each other. When we draw the features, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
Return Type |
Collection<AreaStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.AreaStyle} –> |
Return Type |
DrawingLevel<!– ThinkGeo.MapSuite.PortableCore.DrawingLevel –> |
This solid brush is used to fill in the area features that will draw. You can also optionally specify an outline pen to give the area an outline. The default solid brush has a fill color of transparent, which means it will not draw anything.
Return Type |
GeoSolidBrush<!– ThinkGeo.MapSuite.PortableCore.GeoSolidBrush –> |
Return Type |
Return Type |
Return Type |
None.
Return Type |
This outline pen is used to outline the features that will draw. You can also optionally specify a fill brush to give the area a solid fill. The default outline pen color is transparent, which means it will not draw anything.
Return Type |
This property controls whether the outline pen or the fill brush is drawn first. The default is for the fill brush to be drawn first. If you have the outline pen draw first then the thickness of the pen will be smaller, creating a subtle but noticeable effect.
Return Type |
Return Type |
This property allows you to specify an X offset. When combined with a Y offset, it enables you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to align it with raster satellite data.
Return Type |
Single<!– System.Single –> |
This property allows you to specify a Y offset. When combined with an X offset, it enables you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to align it with raster satellite data.
Return Type |
Return Type |
