thinkgeo.mapsuite.portablecore.proj4memorymode
ThinkGeo.MapSuite.Core.Proj4MemoryMode
  • The enumeration indicates which way are specified to read the projection information.
Items
Default
  • Summary:It's ManagedProj4Projection by default.
Managed
  • Summary:Indciates the application reads the projection information using managed code.
Unmanaged
  • Summary:Indicates the application reads the projection information using unmanaged Proj4 engine.
thinkgeo.mapsuite.portablecore.proj4memorymode.txt · Last modified: 2017/03/16 21:59 (external edit)
