<!– Class –> This class allows you to define how points are drawn on the canvas.
This class allows you to define how points are drawn on the canvas. There are three main drawing types: bitmap, character, and symbol. The bitmap allows you to represent each point with a bitmap. The character allows you to choose a font and an index in the font so you can use that character for the point. This is especially helpful with fonts like Wingdings that have many feature-style graphics. The symbol type is a collection of simple geometric symbols that we have assembled to represent abstract items on the map.
When you select a PointType, you need to be sure to set the various properties associated with that type. The property names are prefixed to help you. For example, all of the character-related properties are prefixed with “Character” and the symbol properties follow a similar pattern.
*System.Object ThinkGeo.MapSuite.PortableCore.Style *ThinkGeo.MapSuite.PortableCore.PointBaseStyle ThinkGeo.MapSuite.PortableCore.PointStyle *ThinkGeo.MapSuite.PortableCore.ClusterPointStyle
PointStyle | This is a constructor for the class. | ||
PointStyle | GeoImage | This is a constructor for the class. | |
PointStyle | GeoFont, Int32, GeoSolidBrush | This is a constructor for the class. | |
PointStyle | PointSymbolType, GeoSolidBrush, Int32 | This is a constructor for the class. | |
PointStyle | PointSymbolType, GeoSolidBrush, GeoPen, Int32 | This is a constructor for the class. |
CloneDeep | Style | Create a copy of style using the deep clone process. | |
Draw | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
Draw | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
DrawSample | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
DrawSample | GeoCanvas | Style | |
GetRequiredColumnNames | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
CloneDeepCore | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
DrawCore | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
DrawSampleCore | GeoCanvas, DrawingRectangleF | Style(overriden) | This method draws a sample feature on the canvas you provided. |
GetRequiredColumnNamesCore | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
Advanced | PointStyleAdvanced | PointBaseStyle | |
CharacterFont | GeoFont | This property gets and sets the font that is used for the character if the PointType is Character. | |
CharacterIndex | Int32 | This property gets and sets the index position of the character you want to use from the font you selected in the CharacterFont property. | |
CharacterSolidBrush | GeoSolidBrush | This property gets and sets the SolidBrush used to color the font character for the point. | |
CustomPointStyles | Collection<PointBaseStyle> | PointBaseStyle | This property returns a collection of area styles allowing you to stack multiple area styles on top of each other. |
DrawingLevel | DrawingLevel | PointBaseStyle | |
Filters | Collection<String> | Style | |
Image | GeoImage | This property gets and sets the image used if the PointType property is NativeImage. | |
ImageScale | Double | This property gets and sets the scale of the image you want to draw. | |
IsActive | Boolean | Style | This property gets and sets the active status of the style. |
Name | String | Style | This property gets and set the name of the style. |
PointType | PointType | This property gets and sets the type of point you want to draw. | |
RequiredColumnNames | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
RotationAngle | Single | PointBaseStyle | This property gets and sets the angle of rotation for the drawing of the point. |
SymbolPen | GeoPen | PointBaseStyle | This property gets and sets the SolidBrush used to draw the oultine of the Symbol. |
SymbolSize | Single | PointBaseStyle | This property gets and sets the size of the symbol if the PointType is Symbol. |
SymbolSolidBrush | GeoSolidBrush | PointBaseStyle | This property gets and sets the SolidBrush used to color the interior of the Symbol. |
SymbolType | PointSymbolType | This property gets and sets the type of symbol you want to use if the PointType is Symbol. | |
XOffsetInPixel | Single | PointBaseStyle | This property gets and sets the X pixel offset for drawing each feature. |
YOffsetInPixel | Single | PointBaseStyle | This property gets and sets the Y pixel offset for drawing each feature. |
FiltersCore | Collection<String> | Style |
This is the default constructor. If you use this constructor, you should set the various properties manually.
If you use this constructor, you should set the various properties manually. Specifically, you will want to set the PointType, which allows you to choose between bitmap, character and symbol as an option for displaying your points.
This constructor is used for bitmap based points.
If you use this constructor, the PointStyle will be set to NativeImage.
| image | GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> | This parameter is the GeoImage of the image you want to use to display the point. |
This constructor is used for character based points.
If you use this constructor, the PointStyle will be set to Character.
| characterFont | GeoFont<!– ThinkGeo.MapSuite.PortableCore.GeoFont –> | This parameter is the font from which the character will be selected. |
| characterIndex | Int32<!– System.Int32 –> | This parameter is the index of the character in the chosen font. |
| characterSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.PortableCore.GeoSolidBrush –> | This parameter is the SolidBrush used to draw the character. |
This constructor is used for symbol-based points (such as squares and circles) with only a fill.
If you use this constructor, the PointStyle will be set to Symbol.
| symbolType | PointSymbolType<!– ThinkGeo.MapSuite.PortableCore.PointSymbolType –> | This parameter is the type of symbol you want to use, such as a square or a circle. |
| symbolSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.PortableCore.GeoSolidBrush –> | This parameter is the SolidBrush you want to use to fill the inside of the symbol. |
| symbolSize | Int32<!– System.Int32 –> | This parameter is the size you want the symbol to be. |
This constructor is used for symbol-based points (such as squares and circles) with a fill and outline.
| symbolPen | GeoPen<!– ThinkGeo.MapSuite.PortableCore.GeoPen –> | This parameter is the Pen used to draw the outline of the symbol. |
| Style<!– ThinkGeo.MapSuite.PortableCore.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
| labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
| shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
| drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
| PointStyleAdvanced<!– ThinkGeo.MapSuite.PortableCore.PointStyleAdvanced –> |
<!– ThinkGeo.MapSuite.PortableCore.PointBaseStyle –> Go Back
This property allows you to set the font from which to select a character index if you choose the Character PointType.
<!– ThinkGeo.MapSuite.PortableCore.PointStyle –> Go Back
You need to specify the index position of the character you want to use from the font you selected. For example, if you choose 1, then we will use the first character in the font you set in the CharacterFont property.
This brush is used to draw the character. It is only used if the PointType is Character. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
| Collection<PointBaseStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.PointBaseStyle} –> |
| DrawingLevel<!– ThinkGeo.MapSuite.PortableCore.DrawingLevel –> |
This property is where you can set the image for the points if the PointType is NativeImage. It uses a GeoImage, so you can either reference a file or supply a stream.
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
When using the PointStyle you choose between a bitmap, a font or a predefined symbol to represent the point. Each of these options has corresponding properties on the point symbol. If you set the type to character, then you need to set the properties that start with “Character,” such as “CharacterFont.” The same is true for the symbol.
| PointType<!– ThinkGeo.MapSuite.PortableCore.PointType –> |
This property controls the rotation of the bitmap, character or symbol, depending on the PointType.
This pen is used to draw the outline of the Symbol. By default the pen draws a transparent (invisible) color, which just leaves you with a fill.
The allows you to make the symbol larger and smaller.
This brush is used to draw the interior of the symbol. It is only used if the PointType is Symbol. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
You can choose between a number of predefined symbols. The symbols are simple geometric objects that are typically used for abstract representations on a map. If there is a specific symbol you need that is not part of our symbol collection, you can submit it to us and we will consider adding it.
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
This property allows you to specify a Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
