thinkgeo.mapsuite.portablecore.openstreetmaplayer
Table of Contents
ThinkGeo.MapSuite.PortableCore.OpenStreetMapLayer
<!– Class –> This class is use for Open Street Map Layer, and you also can get map from open street map server.
Public MethodOpenStreetMapLayer The default constructor
Public MethodOpenStreetMapLayer GeoWebProxy This is the constructor the for the class.
Public MethodCloneDeep Layer Create a copy of Layer using the deep clone process.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetType Object
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodRequestDrawing Layer
Public MethodRequestDrawing RectangleShape Layer
Public MethodRequestDrawing IEnumerable<RectangleShape> Layer
Public MethodRequestDrawing TimeSpan Layer
Public MethodRequestDrawing RectangleShape, TimeSpan Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Layer
Public MethodToString Object
Protected MethodCloneDeepCore Layer Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
Protected MethodCloseCore Layer(overriden) This method closes the Layer and releases any resources it was using.
Protected MethodDrawAttributionCore GeoCanvas, String Layer
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden) This method draws the Layer.
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer This method returns the bounding box of the Layer.
Protected MethodOnDrawingAttribution DrawingAttributionLayerEventArgs Layer
Protected MethodOnDrawingException DrawingExceptionLayerEventArgs Layer
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawnAttribution DrawnAttributionLayerEventArgs Layer
Protected MethodOnDrawnException DrawnExceptionLayerEventArgs Layer
Protected MethodOnRequestedDrawing RequestedDrawingLayerEventArgs Layer
Protected MethodOnRequestingDrawing RequestingDrawingLayerEventArgs Layer
Protected MethodOnSendingWebRequest SendingWebRequestEventArgs
Protected MethodOnSentWebRequest SentWebRequestEventArgs
Protected MethodOpenCore Layer(overriden) This method opens the Layer so that it is initialized and ready to use.
Protected MethodSendWebRequest WebRequest
Protected MethodSendWebRequestCore WebRequest
Public PropertyAttribution String Layer
Public PropertyCachePictureFormat OpenStreetMapLayerPictureFormat The cache for picture format
Public PropertyCustomServerUris Collection<Uri>
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyHasBoundingBox Boolean Layer This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
Public PropertyIsGrayscale Boolean Layer This property gets and sets if the image should be converted to grayscale.
Public PropertyIsNegative Boolean Layer This property gets and sets whether the image should be converted to negative (inverse colors).
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyProjectedTileCache BitmapTileCache
Public PropertyProjectionFromSphericalMercator Projection
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertyTileCache BitmapTileCache
Public PropertyTimeoutInSeconds Int32 Gets or sets a value represents the request timeout from the OpenStreetMap server.
Public PropertyTransparency Single Layer This property gets and sets the amount of transparency to apply to the image.
Public PropertyWebProxy GeoWebProxy This property gets or sets the proxy used for requesting a Web Response.
Public PropertyZoomlevelSet ZoomLevelSet
Protected PropertyIsOpenCore Boolean Layer This property returns true if the Layer is open and false if it is not.
OpenStreetMapLayer()
The constructor initilizes the properties. WebProxy is set to null.
Name Type Description
Go Back
OpenStreetMapLayer(GeoWebProxy)
This constructor initializes a new layer and assgin a web proxy.
webProxy GeoWebProxy<!– ThinkGeo.MapSuite.PortableCore.GeoWebProxy –> The web proxy for OpenStreetMap Server
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> A cloned Layer.
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
Close()
Void<!– System.Void –>
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> This method returns the bounding box of the Layer.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Open()
RequestDrawing()
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –>
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –>
RequestDrawing(TimeSpan)
bufferTime TimeSpan<!– System.TimeSpan –>
RequestDrawing(RectangleShape, TimeSpan)
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
String<!– System.String –>
CloneDeepCore()
CloseCore()
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –>
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –>
OnSendingWebRequest(SendingWebRequestEventArgs)
e SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SendingWebRequestEventArgs –>
<!– ThinkGeo.MapSuite.PortableCore.OpenStreetMapLayer –> Go Back
OnSentWebRequest(SentWebRequestEventArgs)
e SentWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SentWebRequestEventArgs –>
OpenCore()
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
SendWebRequest(WebRequest)
WebResponse<!– System.Net.WebResponse –>
webRequest WebRequest<!– System.Net.WebRequest –>
SendWebRequestCore(WebRequest)
Attribution
Return Type
CachePictureFormat
get or set a OpenStreetMapLayerPictureFormat object
Return Type
OpenStreetMapLayerPictureFormat<!– ThinkGeo.MapSuite.PortableCore.OpenStreetMapLayerPictureFormat –>
CustomServerUris
Return Type
Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –>
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –>
DrawingTime
Return Type
HasBoundingBox
The default value is false.
Return Type
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
Return Type
ProjectedTileCache
Return Type
BitmapTileCache<!– ThinkGeo.MapSuite.PortableCore.BitmapTileCache –>
Return Type
Projection<!– ThinkGeo.MapSuite.PortableCore.Projection –>
Return Type
TileCache
Return Type
TimeoutInSeconds
Return Type
Transparency
Return Type
Single<!– System.Single –>
WebProxy
Return Type
ZoomlevelSet
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –>
IsOpenCore
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
SendingWebRequest
Event Arguments
Event Arguments
SentWebRequest
Event Arguments
Event Arguments
thinkgeo.mapsuite.portablecore.openstreetmaplayer.1440040133.txt.gz · Last modified: 2015/09/21 08:15 (external edit)
