thinkgeo.mapsuite.portablecore.ongeoserializingattribute
ThinkGeo.MapSuite.Core.OnGeoserializingAttribute
When applied to a method, specifies that the method is called before serialization of an object.
    • System.Attribute
      • ThinkGeo.MapSuite.Core.OnGeoserializingAttribute
OnGeoserializingAttribute()
  • Initializes a new instance of the OnGeoserializingAttribute class.
Match(Object)
IsDefaultAttribute()
TypeId
thinkgeo.mapsuite.portablecore.ongeoserializingattribute.txt · Last modified: 2017/03/16 21:59 (external edit)
