thinkgeo.mapsuite.portablecore.nonserializablebasetypeattribute
ThinkGeo.MapSuite.Core.NonSerializableBaseTypeAttribute
Indicates that a type's base type should not be serialized.
    • System.Attribute
      • ThinkGeo.MapSuite.Core.NonSerializableBaseTypeAttribute
NonSerializableBaseTypeAttribute()
  • Creates an instance of NonSerializableBaseTypeAttribute.
Match(Object)
IsDefaultAttribute()
TypeId
thinkgeo.mapsuite.portablecore.nonserializablebasetypeattribute.txt · Last modified: 2017/03/16 21:59 (external edit)
