<!– Class –> This is the base class for NativeTileCache system which inherits from TileCache class.
TileCahce system is very efficient in improving the performance of application, especially when large data or remote server images are included.
*System.Object ThinkGeo.MapSuite.PortableCore.TileCache *ThinkGeo.MapSuite.PortableCore.NativeImageTileCache ThinkGeo.MapSuite.PortableCore.FileNativeImageTileCache
NativeImageTileCache | String, TileImageFormat, TileMatrix | This is the constructor of the class. |
ClearCache | TileCache | This method will clear all the tiles in the tileCache. | |
DeleteTile | Tile | TileCache | This method will delete the target tile passed in. |
DeleteTiles | RectangleShape | TileCache | This method will delete the tiles within the passed in worldExtent. |
GetTile | RectangleShape | This method returns the NativeImageTile corresponding to the tile bounding box passed in. | |
GetTile | Int64, Int64 | This method returns the NativeImageTile corresponding to passed in row and column. | |
GetTiles | RectangleShape | This method returns all the NativeImageTiles within the passed in world extent. | |
SaveTile | Tile | TileCache | This method will save the target tile passed in. |
SaveTiles | GeoImage, RectangleShape | TileCache | This method will save the bitmap with its extent attached into tiles. |
ClearCacheCore | TileCache | This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method. | |
DeleteTileCore | Tile | TileCache | This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method. |
GetTileCore | Int64, Int64 | This abstract method returns the NativeImageTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column. | |
MemberwiseClone | Object | ||
SaveTileCore | Tile | TileCache | This abstract method will save the target tile passed in, for each sub TileCache class must implement this method. |
CacheId | String | TileCache | Gets or sets the id of the TileCache. |
ImageFormat | TileImageFormat | TileCache | Gets or sets the tile image format. |
JpegQuality | Int16 | TileCache | Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg. |
LoadingTileImage | GeoImage | TileCache | This property returns back a preset image showing the Tile is loading. |
NoDataTileImage | GeoImage | TileCache | This property returns back a preset image showing the tile data is missing. |
TileAccessMode | TileAccessMode | TileCache | Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete |
TileMatrix | TileMatrix | TileCache | Gets or sets the TileMatrix which is used in caculation for tiles. |
| cacheId | String<!– System.String –> | This is the cache identifier which marks its difference with other TileCache. |
| imageFormat | TileImageFormat<!– ThinkGeo.MapSuite.PortableCore.TileImageFormat –> | This is the imageFormate showing what kind of image we are trying to save. |
| tileMatrix | TileMatrix<!– ThinkGeo.MapSuite.PortableCore.TileMatrix –> | This is the tile matrix system which is used for caculating tiles. |
This method will not take effect when the ReadOnly is set to true.
<!– ThinkGeo.MapSuite.PortableCore.TileCache –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.PortableCore.Tile –> | The target tile to be deleted. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The target extent to delete all tiles within it. |
| NativeImageTile<!– ThinkGeo.MapSuite.PortableCore.NativeImageTile –> | Returns the NativeImageTile corresponding to the passed in boundingBox. |
| tileBoundingBox | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The target boundingBox for the tile to fetch. |
<!– ThinkGeo.MapSuite.PortableCore.NativeImageTileCache –> Go Back
| NativeImageTile<!– ThinkGeo.MapSuite.PortableCore.NativeImageTile –> | Returns the NativeImageTile corresponding to the passed in row and column. |
| row | Int64<!– System.Int64 –> | The target row for the tile to fetch. |
| column | Int64<!– System.Int64 –> | The target column for the tile to fetch. |
| Collection<NativeImageTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.NativeImageTile} –> | Returns a collection of NativeImageTiles within the passed in worldExtent. |
| extent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The target worldExtent will be used to fetch all the NativeImageTiles from. |
| tile | Tile<!– ThinkGeo.MapSuite.PortableCore.Tile –> | The target tile to be saved. |
| bitmap | GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> | The target bitmap to be saved into tiles. |
| bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The target extent for the bitmap. |
| Int16<!– System.Int16 –> |
If you want it to take effect, you need set the ReadOnly property false.
| TileAccessMode<!– ThinkGeo.MapSuite.PortableCore.TileAccessMode –> |
