<!– Class –> This layer represents multiple Shape Files of the same type.
This layer represents multiple Shape Files of the same type. Many times, you will have multiple Shape Files that represent the same type and you want to draw all of the InternalFeatures in each Shape Files the same way. For example, you may have Shape Files that contain roads separated by state (TXRoads.shp, FLRoads.shp, etc.) but want them to seem like one layer, draw the same way and let you spatially query seamlessly between them. The MultipleShapeFileFeatureLayer accomplishes that goal. When you create the layer, you enter a pattern matching criterion – such as C:\Roads\??Roads.shp“ – and the layer will automatically include all of the Shape Files that match that pattern.
In addition to this, you can also generate single large indexes that index the multiple Shape Files. This means you can have one large road index for all of the road Shape Files, instead of having individual indexes for each layer. Not only is this faster to query, but it also allows you to minimize the number of files you need.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.FeatureLayer ThinkGeo.MapSuite.PortableCore.MultipleShapeFileFeatureLayer
MultipleShapeFileFeatureLayer | This is a constructor for the class. | ||
MultipleShapeFileFeatureLayer | String | This is a constructor for the class. | |
MultipleShapeFileFeatureLayer | String, String | This is a constructor for the class. | |
MultipleShapeFileFeatureLayer | IEnumerable<String> | ||
MultipleShapeFileFeatureLayer | IEnumerable<String>, IEnumerable<String> | This is the constructor for the class. |
![]() BuildIndex | String | This method builds a spatial index for the layer. | |
![]() BuildIndex | String, BuildIndexMode | This method builds a spatial index for the layer. | |
![]() BuildIndex | String, String | This method builds a spatial index for the layer. | |
![]() BuildIndex | String, String, BuildIndexMode | This method builds a spatial index for the layer. | |
![]() BuildIndex | String, String, String, String | This method builds a spatial index for the layer. | |
![]() BuildIndex | String, String, String, String, BuildIndexMode | This method builds a spatial index for the layer. | |
![]() BuildIndex | String[], String[] | This method builds a spatial index for the layer. | |
![]() BuildIndex | String[], String[], BuildIndexMode | This method builds a spatial index for the layer. | |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetIndexPathFileNames | This method returns a collection of the index files and their paths that make up the layer. | ||
GetShapePathFileNames | This method returns a collection of the Shape Files and their paths that make up the layer. | ||
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | Layer | ||
DrawingMarginPercentage | Double | FeatureLayer | This property gets and sets the extra drawing margin as a percentage around the map that draw to ensure that labeling is correct. |
DrawingQuality | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
EditTools | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
Encoding | Encoding | This property gets and sets the encoding information for the DBF. | |
FeatureIdsToExclude | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
FeatureSource | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
HasBoundingBox | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In MultipleShapeFeatureLayer, we override this API and mark it as true. |
IndexFilePattern | String | This property gets and sets the index file pattern that makes up this layer. | |
Indexes | Collection<String> | ||
MaxRecordsToDraw | Int32 | FeatureLayer | |
MultipleShapeFilePattern | String | This property gets and sets the Shape File pattern that makes up this layer. | |
QueryTools | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
ShapeFiles | Collection<String> | ||
WrappingExtent | RectangleShape | FeatureLayer | |
WrappingMode | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
ZoomLevelSet | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
IsOpenCore | Boolean | Layer(overriden) |
DrawingAttribution | DrawingAttributionLayerEventArgs | Layer | |
DrawingException | DrawingExceptionLayerEventArgs | Layer | |
DrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
DrawingProgressChanged | DrawingProgressChangedEventArgs | Layer | |
DrawingWrappingFeatures | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
DrawnAttribution | DrawnAttributionLayerEventArgs | Layer | |
DrawnException | DrawnExceptionLayerEventArgs | Layer | |
RequestedDrawing | RequestedDrawingLayerEventArgs | Layer | |
RequestingDrawing | RequestingDrawingLayerEventArgs | Layer |
This is the default constructor. If you use this constructor, then you need to set to required properties manually.
This constructor allows you to pass in the path and filename pattern to match for the Shape Files.
This constructor allows you to pass in the path and filename pattern to match.
| multipleShapeFilePattern | String<!– System.String –> | This parameter is the matching pattern to determine which Shape Files are loaded. |
This constructor allows you to pass in the path and filename patterns to match for the Shape Files and their index files.
With this constructor you can specify differently-named indexes for the layer. If you have one large index, specify its path and filename here. If you have smaller single indexes, use wildcards to specify a pattern to match instead.
For example, if you had 50 road Shape Files named C:\Roads\??Roads.shp (where ?? is the two-character state abbreviation), but only one large index, then you would specify a string like “C:\Roads\Roads.idx”. If you instead had 50 individual indexes whose names matched the Shape Files, then you would use “C:\Roads\??Roads.idx”.
| multipleShapeFilePattern | String<!– System.String –> | This parameter is the path and filename matching pattern that determines which Shape Files are loaded. |
| indexFilePattern | String<!– System.String –> | This parameter is the path and filename matching pattern that determines which index files are loaded. |
| shapeFiles | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> |
This is the constructor for this class.
This is the constructor for this class. You can pass in a group of shapes and its corresponding indexs like stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer shapeFiles = new stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer { “C:\CA_counties.shp”, “C:\AZ_counties.shp” }; stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer indexFiles = new stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer { “C:\CA_counties.midx”, “C:\AZ_counties.midx” }; In this way, the MultipleShapeFileFeatureLayer will construct from the passing 2 shapes.
| shapeFiles | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | This parameter represents the shape files to construct the MultipleShapeFileFeatureLayer. The format of it should be new stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer { “C:\CA_counties.shp”, “C:\AZ_counties.shp” }. |
| indexes | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | This parameter represents the shape files to construct the ShapeFileFeatureLayer. The format of it should be new stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer { “C:\CA_counties.midx”, “C:\AZ_counties.midx” }. |
<!– static –> This method builds a spatial index for the layer.
This overload allows you to pass in a Shape File path and filename pattern. It will generate indexes for each Shape File it finds, matching the index file names to the Shape File names.
| multipleShapeFilePattern | String<!– System.String –> | This parameter is the matching pattern that defines which Shape Files to include. |
<!– ThinkGeo.MapSuite.PortableCore.MultipleShapeFileFeatureLayer –> Go Back
This overload allows you to pass in a Shape File path and filename pattern and determines if we rebuild index files that already exist. It will generate indexes for each Shape File it finds, matching the index file names to the Shape File names.
This overload allows you to pass in a Shape File path and filename pattern and determines if we re-build index files that already exist. It will generate indexes for each Shape File it finds, matching the index file names to the Shape File names.
| buildIndexMode | BuildIndexMode<!– ThinkGeo.MapSuite.PortableCore.BuildIndexMode –> | This parameter determines whether an index file will be rebuilt if it already exists. |
This overload allows you to pass in a path and filename pattern for Shapes Files and index files. If you use a pattern for the index file name, it will generate indexes for each Shape File it finds, matching the index file names to the Shape File names. Alternatively, if you use a concrete index file name, it will generate one large index instead.
If you enter an indexFilePattern like “C:\Roads\??Roads.idx”, it will build individual indexes for each Shape File and name them according to the pattern. If you enter an absolute name, like “C:\Roads\Roads.idx”, it will create one large index for all of the Shape Files.
| indexFilePattern | String<!– System.String –> | This parameter is the matching pattern of how to name the index (or indexes). |
This overload allows you to pass in a path and filename pattern for Shapes Files and index files. If you use a pattern for the index file name, it will generate indexes for each Shape File it finds, matching the index file names to the Shape File names. Alternatively, if you use a concrete index file name, it will generate one large index instead. It also allows you to specify what to do if an index file already exists.
This method builds a single large index file encompassing many Shape Files and allows you to select only certain features to include, based on regular expression matching on a column.
This index-building method is very useful when you have a large number of Shape Files that contain only certain records you want. For example, you may have an individual Shape File for the states of Texas and Florida that contains only those states' roads. They are named TXRoads.shp for Texas and FLRoads.shp for Florida. Inside of these Shape Files there is a column that determines whether the roads are normal streets or highways. You, of course, want to draw highways differently. You could use a ValueStyle, but that would be slow because you'd have to look though all of the records at runtime to determine which are the highways. A better solution is to build a custom index that only has highways in it. In this way, you generate the index once and then runtime performance is fast.
In our scenario, we would create an index to include all of the road Shape Files by using the pattern “*Roads.shp”. This will make sure we get both the Texas and Florida roads. Next, we specify the RoadType column as the column parameter. Then we provide a regular expression match that picks out all of the highways, and name the resulting index “Highways.idx”. We can then build another, separate index just for the normal streets. In this way, we can quickly sort the roads from the highways – and we didn't have to cut up our Shape Files to do it.
| columnName | String<!– System.String –> | This parameter is the column name you want to apply the regular expression towards. |
| regularExpression | String<!– System.String –> | This parameter is the regular expression you want to use to select certain features for your index. |
| indexFilename | String<!– System.String –> | This parameter is the name of the index file you want to generate for the features that match the regular expression. |
This method builds a single large index file encompassing many Shape Files and allows you to select only certain features to include, based on regular expression matching on a column. It also allows you to specify what to do if an index file already exists.
| buildIndexMode | BuildIndexMode<!– ThinkGeo.MapSuite.PortableCore.BuildIndexMode –> | This parameter determines whether the index file will be rebuilt if it already exists. |
| multipleShapeFiles | String[]<!– System.Stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer –> | This parameter represents the shape files to construct the MultipleShapeFileFeatureLayer. The format of it should be new stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer { “C:\CA_counties.shp”, “C:\AZ_counties.shp” }. |
| multipleShapeFileIndexes | String[]<!– System.Stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer –> | This parameter represents the shape files to construct the ShapeFileFeatureLayer. The format of it should be new stringthinkgeo.mapsuite.portablecore.multipleshapefilefeaturelayer { “C:\CA_counties.midx”, “C:\AZ_counties.midx” }. |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of the index files and their paths that make up the layer. |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of the Shape Files and their paths that make up the layer. |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
This method raises the DrawingFeatures event.
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.PortableCore.FeatureLayer –> Go Back
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This method sets up the EditTools and QueryTools objects.
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
This extra margin that we draw exists so that labels match up if they are partially cut off.
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
| DrawingQuality<!– ThinkGeo.MapSuite.PortableCore.DrawingQuality –> |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
| EditTools<!– ThinkGeo.MapSuite.PortableCore.EditTools –> |
| Encoding<!– System.Text.Encoding –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
| FeatureSource<!– ThinkGeo.MapSuite.PortableCore.FeatureSource –> |
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
| QueryTools<!– ThinkGeo.MapSuite.PortableCore.QueryTools –> |
| WrappingMode<!– ThinkGeo.MapSuite.PortableCore.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
| ZoomLevelSet<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
