thinkgeo.mapsuite.portablecore.linkrecords
ThinkGeo.MapSuite.Core.LinkRecords
LinkRecords()
LinkRecords(String)
  • name
Open()
Close()
Dispose()
GetColumns()
GetColumnValues(Int32,IEnumerable<String>)
  • Type:Dictionary<String,Object>
  • recordIndex
  • returningColumnNames
    • Type:IEnumerable<String>
MoveNext()
Reset()
GetEnumerator()
OpenCore()
CloseCore()
DisposeCore()
GetCurrentRecord()
GetCurrentRecordCore()
GetColumnsCore()
GetColumnValuesCore(Int32,IEnumerable<String>)
  • recordIndex
MoveNextCore()
ResetCore()
ColumnNamesToExclude
  • Type:Collection<String>
Current
IsCacheEnabled
IsOpen
RequiredColumnNames
ReturningColumnNames
BxY=
Position
ChY=
DBY=
System.Collections.IEnumerator.Current
thinkgeo.mapsuite.portablecore.linkrecords.txt · Last modified: 2017/03/16 21:59 (external edit)
