thinkgeo.mapsuite.portablecore.layerdrawneventargs
ThinkGeo.MapSuite.Core.LayerDrawnEventArgs
      • ThinkGeo.MapSuite.Core.LayerDrawnEventArgs
LayerDrawnEventArgs()
LayerDrawnEventArgs(Layer,RectangleShape,Object)
  • None
  • currentLayer
    • Type:Layer
    • Description:This parameter is the layer that has drawn.
  • worldExtent
    • Description:This parameter is the world extent that has drawn.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
CurrentLayer
  • This property gets and sets layer that has drawn.
  • None
WorldExtent
  • This property gets and sets the world extent to draw.
  • None
NativeImage
  • This property gets and sets the GeoImage or native image that we are drawing on.
  • None
thinkgeo.mapsuite.portablecore.layerdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
