thinkgeo.mapsuite.portablecore.layerdrawingeventargs
ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
      • ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
LayerDrawingEventArgs()
LayerDrawingEventArgs(Layer,RectangleShape,Object)
  • currentLayer
    • Type:Layer
    • Description:This parameter is the layer you will be drawing.
  • worldExtent
    • Description:This parameter is the world extent you are drawing.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
Cancel
This property gets and sets the value that indicates you want to cancel the layer from drawing.
CurrentLayer
This property gets and sets current layer that will be drawn.
WorldExtent
This property gets and sets the world extent that will be drawn.
NativeImage
This property gets and sets the GeoImage or native image that we are drawing on.
thinkgeo.mapsuite.portablecore.layerdrawingeventargs.1442823142.txt.gz · Last modified: 2015/09/21 08:12 by admin
