thinkgeo.mapsuite.portablecore.layerdrawingeventargs
ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
      • ThinkGeo.MapSuite.Core.LayerDrawingEventArgs
LayerDrawingEventArgs()
LayerDrawingEventArgs(Layer,RectangleShape,Object)
  • None
  • currentLayer
    • Type:Layer
    • Description:This parameter is the layer you will be drawing.
  • worldExtent
    • Description:This parameter is the world extent you are drawing.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
Cancel
  • This property gets and sets the value that indicates you want to cancel the layer from drawing.
  • None
CurrentLayer
  • This property gets and sets current layer that will be drawn.
  • None
WorldExtent
  • This property gets and sets the world extent that will be drawn.
  • None
NativeImage
  • This property gets and sets the GeoImage or native image that we are drawing on.
  • None
thinkgeo.mapsuite.portablecore.layerdrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
