thinkgeo.mapsuite.portablecore.layerdrawingeventargs
ThinkGeo.MapSuite.PortableCore.LayerDrawingEventArgs
<!– Class –> This is the event arguments class for the LayerDrawing event on the MapEngine class. It is raised before the layer is drawn.
This is the event arguments class for the LayerDrawing event on the MapEngine class. It is raised before the layer is drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.PortableCore.LayerDrawingEventArgs
Public MethodLayerDrawingEventArgs This is a constructor for the class.
Public MethodLayerDrawingEventArgs Layer, RectangleShape, Object This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCancel Boolean This property gets and sets the value that indicates you want to cancel the layer from drawing.
Public PropertyCurrentLayer Layer This property gets and sets current layer that will be drawn.
Public PropertyNativeImage Object This property gets and sets the GeoImage or native image that we are drawing on.
Public PropertyWorldExtent RectangleShape This property gets and sets the world extent that will be drawn.
LayerDrawingEventArgs()
Overloads
Name Type Description
Go Back
LayerDrawingEventArgs(Layer, RectangleShape, Object)
Overloads
This constructor allows you to set the Layer to be drawn, the world extent, and the image you are drawing on.
currentLayer Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> This parameter is the layer you will be drawing.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> This parameter is the world extent you are drawing.
nativeImage Object<!– System.Object –> This parameter is the GeoImage or native map image.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Cancel
Return Type
<!– ThinkGeo.MapSuite.PortableCore.LayerDrawingEventArgs –> Go Back
CurrentLayer
Return Type
NativeImage
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.portablecore.layerdrawingeventargs.1440040132.txt.gz · Last modified: 2015/09/21 08:12 (external edit)
