thinkgeo.mapsuite.portablecore.labelduplicaterule
ThinkGeo.MapSuite.Core.LabelDuplicateRule
  • This enumeration defines the different labeling duplicate rules.
  • Duplicate refers to the condition where a label's text is exactly the same as another label. An example case where this is common is a road where each intersection is its own segment. In such a case, you do not want to label each segment as it would be highly redundant.
Items
OneDuplicateLabelPerQuadrant
  • Summary:There may be only one label in each of the four quadrants.
NoDuplicateLabels
  • Summary:There may be no duplicate labels.
UnlimitedDuplicateLabels
  • Summary:There may be an unlimited number of duplicate labels.
thinkgeo.mapsuite.portablecore.labelduplicaterule.txt · Last modified: 2017/03/16 21:59 (external edit)
