<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.RasterLayer ThinkGeo.MapSuite.PortableCore.KmlRasterLayer
KmlRasterLayer | |||
KmlRasterLayer | String |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetHorizontalResolution | RasterLayer | This method returns the horizontal resolution of the image. | |
GetProjectionText | RasterLayer | This method returns the projection parameters of the current layer. | |
GetVerticalResolution | RasterLayer | This method returns the vertical resolution of the image. | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
BlueTranslation | Single | RasterLayer | This property gets and sets the amount of blue to apply to the image. |
GreenTranslation | Single | RasterLayer | This property gets and sets the amount of green to apply to the image. |
HasBoundingBox | Boolean | Layer(overriden) | |
HasProjectionText | Boolean | RasterLayer | This property returns true if the RasterLayer contains projection parameters and false if it does not contain any projection parameters. |
ImageSource | RasterSource | RasterLayer | This property gets and sets the ImageSource used by the RasterLayer. |
IsGrayscale | Boolean | RasterLayer | This property gets and sets if the image should be converted to grayscale. |
IsNegative | Boolean | RasterLayer | This property gets and sets whether the image should be converted to negative (inverse colors). |
KeyColors | Collection<GeoColor> | RasterLayer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
KmlPathFilename | String | ||
LowerThreshold | Double | RasterLayer | This property gets and sets the lower threshold in the scale at which to display the image. |
RedTranslation | Single | RasterLayer | This property gets and sets the amount of red to apply to the image. |
UpperThreshold | Double | RasterLayer | This property gets and sets the upper threshold in the scale at which to display the image. |
IsOpenCore | Boolean | Layer(overriden) |
| kmlPathFilename | String<!– System.String –> |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
| Single<!– System.Single –> | This method returns the horizontal resolution of the image. |
<!– ThinkGeo.MapSuite.PortableCore.RasterLayer –> Go Back
| String<!– System.String –> | This method returns the projection parameters of the current layer. |
| Single<!– System.Single –> | This method returns the vertical resolution of the image. |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
The set for this property is protected and only intended to be used by developers who are creating their own ImageSources. This is the main property to set for developers who are creating their own RasterLayer derivatives.
| RasterSource<!– ThinkGeo.MapSuite.PortableCore.RasterSource –> |
| Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.GeoColor} –> |
<!– ThinkGeo.MapSuite.PortableCore.KmlRasterLayer –> Go Back
Below the lower threshold in scale, the image will not be displayed. This, in conjunction with the UpperThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Above the upper threshold in scale, the image will not be displayed. This, in conjunction with the LowerThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| StreamLoadingEventArgs<!– ThinkGeo.MapSuite.PortableCore.StreamLoadingEventArgs –> |
