<!– Class –> This class uses the grid file provided.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.FeatureLayer ThinkGeo.MapSuite.PortableCore.InMemoryGridFeatureLayer
Name | Parameters | DeclaringType | Summary | |
![]() | This is the default constructor for the class. | |||
![]() | InMemoryGridFeatureLayer]] | GridCell[, ] |
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() ![]() | GridDefinition, GridInterpolationModel, Stream | ||
![]() ![]() | GridDefinition, GridInterpolationModel | ||
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | Object | ||
![]() | Object | ||
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | RectangleShape | Layer | |
![]() | Layer | ||
![]() | RectangleShape, TimeSpan | Layer | |
![]() | TimeSpan | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | ||
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Layer(overriden) | This method returns the bounding box of the FeatureLayer. | |
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingFeaturesEventArgs | FeatureLayer | This method raises the DrawingFeatures event. |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | FeatureLayer | This method sets up the EditTools and QueryTools objects. | |
![]() | String | Layer | |
![]() | Double | Gets the cell size from the grid. | |
![]() | Int32 | Gets the column number from the grid. | |
![]() | String | ||
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | Double | FeatureLayer | This property gets and sets the extra drawing margin as a percentage around the map that draw to ensure that labeling is correct. |
![]() | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
![]() | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
![]() | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
![]() | GridCell[,] | ||
![]() | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GridFeatureLayer, we override this API and mark it as true. |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Int32 | FeatureLayer | |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | Double | Gets the NoDataValue from the grid. | |
![]() | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
![]() | Int32 | Gets the row number from the grid. | |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | RectangleShape | FeatureLayer | |
![]() | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
![]() | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
![]() | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
Name | Type | Description |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
<!– static –>
gridDefinition | GridDefinition<!– ThinkGeo.MapSuite.PortableCore.GridDefinition –> | |
gridInterpolationModel | GridInterpolationModel<!– ThinkGeo.MapSuite.PortableCore.GridInterpolationModel –> | |
outputStream | Stream<!– System.IO.Stream –> |
<!– ThinkGeo.MapSuite.PortableCore.InMemoryGridFeatureLayer –> Go Back
<!– static –>
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
String<!– System.String –> |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
This method is called from the concrete public method GetBoundingBox. It returns the bounding box of the FeatureLayer.
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the FeatureLayer. |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.PortableCore.FeatureLayer –> Go Back
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
Return Type |
Return Type |
Double<!– System.Double –> |
Return Type |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
This extra margin that we draw exists so that labels match up if they are partially cut off.
Return Type |
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
Return Type |
DrawingQuality<!– ThinkGeo.MapSuite.PortableCore.DrawingQuality –> |
Return Type |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
Return Type |
EditTools<!– ThinkGeo.MapSuite.PortableCore.EditTools –> |
Return Type |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
Return Type |
FeatureSource<!– ThinkGeo.MapSuite.PortableCore.FeatureSource –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
Return Type |
QueryTools<!– ThinkGeo.MapSuite.PortableCore.QueryTools –> |
Return Type |
Return Type |
Return Type |
Single<!– System.Single –> |
Return Type |
Return Type |
WrappingMode<!– ThinkGeo.MapSuite.PortableCore.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
Return Type |
ZoomLevelSet<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –> |
Return Type |
Event Arguments |
Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
