thinkgeo.mapsuite.portablecore.iconvalueitem
ThinkGeo.MapSuite.PortableCore.IconValueItem
<!– Class –> This class is a single item in an IconValueStyle.
This item is used in the IconValueStyle to determine which way to draw the feature based on the FieldValue property.
How IconValueStyle works:
When you create an IconValueStyle, you need to add multiple IconValueItems to its collection. You input the column name in the IconValueStyle and it will compare the data's value to each IconValueItem's FieldValue. If they match, then it will draw the Feature using the properties of the IconValueItem. In this way, you can render different data with different icons or text.
The MinimumLength and MaximumLength properties are important because they are used to ensure that a properly sized icon is used to draw things like road signs. For example, you can set the minimum and maximum values so that the sign icon for a single-digit road number uses one icon, while a two-digit road uses another, wider sign icon in a separate IconValueItem.
Public MethodIconValueItem This is the constructor for the class.
Public MethodIconValueItem String, String, TextStyle This is the constructor for the class.
Public MethodIconValueItem String, GeoImage, TextStyle This is the constructor for the class.
Public MethodGetIconImage This method gets the icon we will draw as a GeoImage.
Public MethodGetType Object
Public MethodToString Object
Public PropertyFieldValue String This property gets and sets the field value that has to match in the IconValueStyle.
Public PropertyIconFilePathName String This property gets and sets the path and filename of the icon that will be drawn.
Public PropertyTextStyle TextStyle This property gets and sets the style that will be used to draw the text in the icon.
Public PropertyTextValueLengthMax Int32 This property gets and sets the maximum string length for this item to match.
Public PropertyTextValueLengthMin Int32 This property gets and sets the minimum string length for this item to match.
IconValueItem()
Overloads
This is the default constructor for the class.
If you use the constructor, then you should set all the properties manually.
Name Type Description
Go Back
IconValueItem(String, String, TextStyle)
Overloads
This constructor allows you to set the field value, the path and filename of the icon and the text style you want to use to render it.
You would typically use this constructor if you are using an icon that's located on disk. If you need to use an image from a stream instead, there is another overload that takes a GeoImage.
fieldValue String<!– System.String –> This parameter is the value you want to match.
iconPathFilename String<!– System.String –> This parameter is the path and filename of the image you want to use.
textStyle TextStyle<!– ThinkGeo.MapSuite.PortableCore.TextStyle –> This parameter is the TextStyle of how you want the text drawn.
Go Back
IconValueItem(String, GeoImage, TextStyle)
Overloads
This constructor allows you to set the field value, the GeoImage, and the text style you want to use to render it.
You will typically use this overload if you need to use a stream for the image. If you need to use a file located on disk instead, there is another overload that takes the path and filename to an image.
iconImage GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> This parameter is the GeoImage of the image you want to use.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetIconImage()
This method is used when drawing to get the image as a GeoImage. We will internally either pass along the GeoImage the user set, or create a GeoImage from the IconFilePathName that was set.
GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> This method gets the icon we will draw as a GeoImage.
<!– ThinkGeo.MapSuite.PortableCore.IconValueItem –> Go Back
Type<!– System.Type –>
Void<!– System.Void –>
FieldValue
For an explanation on how the IconValueStyle works, see the IconValueStyle Class remarks.
Return Type
IconFilePathName
If you need to use a GeoImage, you can set the GeoImage in the constructor or use the property.
Return Type
TextStyle
Return Type
TextValueLengthMax
This is an important property because it is used to ensure that that a properly sized icon is used to draw things like road signs. For example, you can set the minimum and maximum values so that the sign icon for a single-digit road number uses one icon, while a two-digit road uses another, wider sign icon in a separate IconValueItem.
Return Type
TextValueLengthMin
Return Type
thinkgeo.mapsuite.portablecore.iconvalueitem.1440040132.txt.gz · Last modified: 2015/09/21 08:10 (external edit)
