<!– Class –> HeatLayer allows you to better visualize data by making areas of high concentration “hotter” using warmer colors and low density areas visually cooler.
HeatLayer | This is the default constructor of the class. | ||
HeatLayer | FeatureSource | This is a constructor for the class. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
CloseCore | Layer(overriden) | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. |
FeatureSource | FeatureSource | This property gets the FeatureSource for the HeatLayer. | |
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
HeatStyle | HeatStyle | Gets or sets the style of HeatLayer. | |
LowerScale | Double | Specifies the lower threshold of the layer. | |
UpperScale | Double | Specifies the upper threshold of the layer. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
This constructor allows you to pass in the FeatureSource.
| featureSource | FeatureSource<!– ThinkGeo.MapSuite.PortableCore.FeatureSource –> | This parameter is the FeatureSource that use to be drawn. |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
The FeatureSource is the provider of data to the HeatLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the HeatLayer, in the constructor you set the FeatureSource you want to use.
<!– ThinkGeo.MapSuite.PortableCore.HeatLayer –> Go Back
The default value is false.
If this property is not set, it will use the default HeatStyle.
| HeatStyle<!– ThinkGeo.MapSuite.PortableCore.HeatStyle –> |
The HeatLayer only displays when the currentScale is less than or equal to UpperScale and greater than or equal to <strong>LowerScale</strong>, otherwise it won't show anything.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
