<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.IsoLineLayer ThinkGeo.MapSuite.PortableCore.GridIsoLineLayer
![]() | String | ||
![]() | String, IEnumerable<Double> | ||
![]() | String, IEnumerable<Double>, Double, Double | ||
![]() | String, IEnumerable<Double>, Double, Double, IsoLineType |
Name | Parameters | DeclaringType | Summary | |
![]() | Layer | Create a copy of Layer using the deep clone process. | ||
![]() | Layer | This method closes the Layer and releases any resources it was using. | ||
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. | |
![]() | Object | Object | ||
![]() | Layer | This method returns the bounding box of the Layer. | ||
![]() | Object | |||
![]() ![]() | GetIsoFeatures]] | GridCell[, ], IEnumerable<Double>, String, IsoLineType, Double | IsoLineLayer | |
![]() ![]() | GetIsoFeatures]] | GridCell[, ], IEnumerable<Double>, String, IsoLineType | IsoLineLayer | |
![]() ![]() | GridFeatureSource, IEnumerable<Double>, String, IsoLineType | IsoLineLayer | ||
![]() ![]() | GetIsoLineLevels]] | GridCell[, ], Int32 | IsoLineLayer | |
![]() ![]() | IEnumerable<Double>, Int32 | IsoLineLayer | ||
![]() ![]() | Dictionary<PointShape, Double>, Int32 | IsoLineLayer | ||
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | ||
![]() | RectangleShape, TimeSpan | Layer | ||
![]() | TimeSpan | Layer | ||
![]() | IEnumerable<RectangleShape> | Layer | ||
![]() | RectangleShape | Layer | ||
![]() | Layer | |||
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | ||
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | GeoCanvas, Collection<SimpleCandidate> | IsoLineLayer(overriden) | |
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | StreamLoadingEventArgs | ||
![]() | Layer(overriden) |
![]() | String | Layer | |
![]() | Collection<Style> | IsoLineLayer | |
![]() | String | IsoLineLayer | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | String | ||
![]() | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<Double> | IsoLineLayer | |
![]() | IsoLineType | IsoLineLayer | |
![]() | Double | IsoLineLayer | |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
Name | Type | Description |
gridPathFileName | String<!– System.String –> |
gridPathFileName | String<!– System.String –> | |
isoLineLevels | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> |
isoLineLevels | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> | |
lowerScale | Double<!– System.Double –> | |
upperScale | Double<!– System.Double –> |
upperScale | Double<!– System.Double –> | |
isoLineType | IsoLineType<!– ThinkGeo.MapSuite.PortableCore.IsoLineType –> |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
<!– static –>
Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.Feature} –> |
gridMatrix | GridCell[,]<!– ThinkGeo.MapSuite.PortableCore.GridCell, –> | |
dataValueColumnName | String<!– System.String –> | |
isoLineType | IsoLineType<!– ThinkGeo.MapSuite.PortableCore.IsoLineType –> | |
noDataValue | Double<!– System.Double –> |
<!– ThinkGeo.MapSuite.PortableCore.IsoLineLayer –> Go Back
<!– static –>
<!– static –>
gridFeatureSource | GridFeatureSource<!– ThinkGeo.MapSuite.PortableCore.GridFeatureSource –> | |
<!– ThinkGeo.MapSuite.PortableCore.GridIsoLineLayer –> Go Back
<!– static –>
Collection<Double><!– System.Collections.ObjectModel.Collection{System.Double} –> |
isoLineLevelCount | Int32<!– System.Int32 –> |
<!– static –>
dataValues | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> | |
<!– static –>
dataPoints | Dictionary<PointShape,Double><!– System.Collections.Generic.Dictionary{ThinkGeo.MapSuite.PortableCore.PointShape,System.Double} –> | |
Type<!– System.Type –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
<!– ThinkGeo.MapSuite.PortableCore.IsoLineLayer(overriden) –> Go Back
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
e | StreamLoadingEventArgs<!– ThinkGeo.MapSuite.PortableCore.StreamLoadingEventArgs –> |
Return Type |
Return Type |
Collection<Style><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.Style} –> |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
Return Type |
The default value is false.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Single<!– System.Single –> |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
