thinkgeo.mapsuite.portablecore.geotiffrastersource
ThinkGeo.MapSuite.Core.GeoTiffRasterSource
    • ThinkGeo.MapSuite.Core.RasterSource
      • ThinkGeo.MapSuite.Core.GeoTiffRasterSource
GeoTiffRasterSource()
  • This is the constructor the for the class. If you use this constructor then you need to set the required properties manually.
  • None
GeoTiffRasterSource(String)
  • This is the constructor for the class.
  • This is typically the constructor you want to use for this class. It allows you to pass in the TIFF file you wish to work with. Note that the TIFF file is not accessed or opened until you call the open command of the class.
  • imagePathFilename
    • Description:This parameter represents the path and file name of the TIFF file you want to load into the class for display.
GeoTiffRasterSource(String,String)
  • This is typically the constructor you want to use for this class. It allows you to pass in the TIFF file you wish to work with and world file belongs to it. Note that the TIFF file is not accessed or opened until you call the open command of the class.
  • imagePathFilename
  • worldfilePathFilename
    • Description:This parameter represents the path and file name of the world file you want to load into the class for display.
GeoTiffRasterSource(String,RectangleShape)
  • This is typically the constructor you want to use for this class. It allows you to pass in the TIFF file you wish to work with and image extent belongs to it. Note that the TIFF file is not accessed or opened until you call the open command of the class.
  • imagePathFilename
  • imageExtent
    • Description:This parameter represents the extent of the world file you want to load into the class for display.
CloneDeep()
GetWorldFileText()
GetImageWidth()
GetImageHeight()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
GetBoundingBox()
GetProjectionText()
Open()
Close()
GetImage(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
GetImageWidthCore()
GetImageHeightCore()
GetBoundingBoxCore()
OpenCore()
GetImageCore(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
CloseCore()
CloneDeepCore()
OnOpeningRasterSource(OpeningRasterSourceEventArgs)
OnOpenedRasterSource(OpenedRasterSourceEventArgs)
OnClosingRasterSource(ClosingRasterSourceEventArgs)
OnClosedRasterSource(ClosedRasterSourceEventArgs)
GetProjectionTextCore()
PathFilename
  • This property gets and sets the path and filename of the TIFF file you want to use.
  • None.
LibraryType
Projection
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
IsNegative
IsGrayscale
IsOpen
HasProjectionText
HasProjectionTextCore
OpeningRasterSource
Event Arguments:OpeningRasterSourceEventArgs
OpenedRasterSource
Event Arguments:OpenedRasterSourceEventArgs
ClosingRasterSource
Event Arguments:ClosingRasterSourceEventArgs
ClosedRasterSource
Event Arguments:ClosedRasterSourceEventArgs
thinkgeo.mapsuite.portablecore.geotiffrastersource.txt · Last modified: 2017/03/16 21:59 (external edit)
