thinkgeo.mapsuite.portablecore.geotexturebrush
ThinkGeo.MapSuite.Core.GeoTextureBrush
    • ThinkGeo.MapSuite.Core.GeoBrush
      • ThinkGeo.MapSuite.Core.GeoTextureBrush
GeoTextureBrush(GeoImage)
You will use this constructor when you want to use the Tile wrap mode and you want the image fill to encompass the entire shape.
  • image
    • Type:GeoImage
    • Description:This parameter is the image you want to use as the texture.
GeoTextureBrush(GeoImage,DrawingRectangleF)
This method allows you to pass in a rectangle in screen coordinates to determine how much of the area is textured.
  • image
    • Type:GeoImage
  • rectangleF
    • Description:This parameter is a rectangle (in screen coordinates) that specifies the area you want to use for the texture.
GeoTextureBrush(GeoImage,GeoWrapMode)
  • image
    • Type:GeoImage
  • wrapMode
    • Description:This parameter determines the way the texture wraps when the area to fill is larger than the texture.
GeoTextureBrush(GeoImage,GeoWrapMode,DrawingRectangleF)
  • image
    • Type:GeoImage
  • wrapMode
  • rectangleF
CloneDeep()
CloneDeepCore()
GeoImage
This property gets and sets the GeoImage used for the texture fill.
DrawingRectangleF
This property gets and sets the screen rectangle used to fill the texture.
GeoWrapMode
This property gets and sets the wrap mode that is used to determine how an area is filled if the area is larger than the texture.
Id
  • Type:Int64
thinkgeo.mapsuite.portablecore.geotexturebrush.1442822971.txt.gz · Last modified: 2015/09/21 08:09 by admin
