thinkgeo.mapsuite.portablecore.geocollection_1
ThinkGeo.MapSuite.Core.GeoCollection<T>
    • System.Collections.ObjectModel.Collection<T>
      • ThinkGeo.MapSuite.Core.GeoCollection<T>
GeoCollection`1()
  • This is the default constructor for the class.
  • None
GetKeys()
  • This method returns a collection of the keys in the collection.
  • None
  • Type:Collection<String>
  • Description:This method returns a collection of the keys in the collection.
Add(String,T)
  • key
  • item
    • Type:T
Add(T)
  • item
    • Type:T
Insert(Int32,T)
  • index
  • item
    • Type:T
Insert(Int32,String,T)
  • index
  • key
  • item
    • Type:T
Remove(String)
  • This method removes an item from the collection based on the specified key.
  • None
  • Description:None
  • key
    • Description:This parameter is the key of the item you want to remove.
MoveUp(Int32)
  • This method moves an item up in the collection.
  • None
  • Description:None
  • index
    • Description:This parameter is the index of the item in the collection.
MoveUp(String)
  • None
  • Description:None
  • key
    • Description:This parameter is the key of the item in the collection.
MoveUp(T)
  • item
    • Type:T
MoveDown(Int32)
  • This method moves an item down in the collection.
  • None
  • Description:None
  • index
MoveDown(String)
  • None
  • Description:None
  • key
    • Description:This parameter is the key of the item in the dictionary.
MoveDown(T)
  • item
    • Type:T
MoveToTop(Int32)
  • This method moves the item at the specified index to the top of the collection.
  • Description:None
  • index
    • Description:This parameter is the index of the item you want move to the top of the collection.
MoveToTop(String)
  • This method moves the item with the specified key to the top of the collection.
  • Description:None
  • key
    • Description:This parameter is the key of the item you want move to the top of the collection.
MoveToTop(T)
  • item
    • Type:T
MoveToBottom(Int32)
  • This method moves the item at the specified index to the bottom of the collection.
  • Description:None
  • index
    • Description:This parameter is the index of the item you want move to the bottom of the collection.
MoveToBottom(String)
  • This method moves the item with the specified key to the bottom of the collection.
  • Description:None
  • key
    • Description:This parameter is the key of the item you want move to the bottom of the collection.
MoveToBottom(T)
  • item
    • Type:T
MoveTo(Int32,Int32)
  • This method moves the item at fromIndex to the location of toIndex in the collection.
  • Description:None
  • fromIndex
    • Description:This parameter is the index of the item you want move from in the collection.
  • toIndex
    • Description:This parameter is the target index that you want to move the item to in the collection.
MoveTo(String,Int32)
  • This method moves the item with the key you specified to the location of toIndex in the collection.
  • Description:None
  • key
    • Description:This parameter is the key of item you want to move in the collection.
  • toIndex
MoveTo(T,Int32)
  • item
    • Type:T
  • toIndex
Contains(String)
  • This method returns whether an item is in the collection based on the specified key.
  • None
  • Description:This method returns whether an item is in the collection based on the specified key.
  • key
    • Description:This parameter is the key of the item you are searching for.
Add(T)
  • item
    • Type:T
Clear()
CopyTo(T[],Int32)
  • array
    • Type:T[]
  • index
Contains(T)
  • item
    • Type:T
GetEnumerator()
  • Type:IEnumerator<T>
IndexOf(T)
  • item
    • Type:T
Insert(Int32,T)
  • index
  • item
    • Type:T
Remove(T)
  • item
    • Type:T
RemoveAt(Int32)
  • index
OnInserting(InsertingGeoCollectionEventArgs)
OnInserted(InsertedGeoCollectionEventArgs)
OnRemoving(RemovingGeoCollectionEventArgs)
OnRemoved(RemovedGeoCollectionEventArgs)
OnAdding(AddingGeoCollectionEventArgs)
OnAdded(AddedGeoCollectionEventArgs)
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
InsertItem(Int32,T)
  • index
  • item
    • Type:T
RemoveItem(Int32)
  • This method removes an item from the collection based on the specified index.
  • None
  • Description:None
  • index
    • Description:This parameter is the index of the item you want to remove.
ClearItems()
  • This method clears the items from the collection.
  • None
  • Description:None
SetItem(Int32,T)
  • index
  • item
    • Type:T
OnCollectionChanged(NotifyCollectionChangedEventArgs)
  • e
    • Type:NotifyCollectionChangedEventArgs
OnPropertyChanged(PropertyChangedEventArgs)
  • e
    • Type:PropertyChangedEventArgs
Item
  • Type:T
Count
Item
  • Type:T
Items
  • Type:IList<T>
Inserting
Event Arguments:InsertingGeoCollectionEventArgs
Inserted
Event Arguments:InsertedGeoCollectionEventArgs
Removing
Event Arguments:RemovingGeoCollectionEventArgs
Removed
Event Arguments:RemovedGeoCollectionEventArgs
Adding
Event Arguments:AddingGeoCollectionEventArgs
Added
Event Arguments:AddedGeoCollectionEventArgs
ClearingItems
Event Arguments:ClearingItemsGeoCollectionEventArgs
ClearedItems
Event Arguments:ClearedItemsGeoCollectionEventArgs
CollectionChanged
Event Arguments:
PropertyChanged
Event Arguments:
thinkgeo.mapsuite.portablecore.geocollection_1.txt · Last modified: 2017/03/16 21:59 (external edit)
