thinkgeo.mapsuite.portablecore.gaussiankriginggridinterpolationmodel
ThinkGeo.MapSuite.Core.GaussianKrigingGridInterpolationModel
    • ThinkGeo.MapSuite.Core.GridInterpolationModel
      • ThinkGeo.MapSuite.Core.KrigingGridInterpolationModel
        • ThinkGeo.MapSuite.Core.GaussianKrigingGridInterpolationModel
GaussianKrigingGridInterpolationModel()
GaussianKrigingGridInterpolationModel(IDictionary<PointShape,Double>)
  • points
    • Type:IDictionary<PointShape,Double>
GaussianKrigingGridInterpolationModel(IDictionary<PointShape,Double>,Int32)
  • points
  • numberOfRefrencedPoints
GetSemivariance(Double,EmpiricalFunctionCoefficients)
  • distance
GetEmpiricalFunctionCoefficients(Int32,Double[,],Double[,],Double)
  • numberOfPoints
  • distance
    • Type:Double[,]
  • semivariances
    • Type:Double[,]
  • maxRange
Interpolate(RectangleShape,GridDefinition)
GetSillSlopeCore(Double,Double)
  • distance
  • range
InterpolateCore(RectangleShape,GridDefinition)
GetSemivarianceCore(Double,EmpiricalFunctionCoefficients)
  • distance
GetSillSlope(Double,Double)
  • distance
  • range
GetEmpiricalFunctionCoefficientsCore(Int32,Double[,],Double[,],Double)
  • points
  • distance
    • Type:Double[,]
  • semivariances
    • Type:Double[,]
  • maxRange
Points
NumberOfReferencedPoints
thinkgeo.mapsuite.portablecore.gaussiankriginggridinterpolationmodel.txt · Last modified: 2017/03/16 21:59 (external edit)
