thinkgeo.mapsuite.portablecore.empiricalfunctioncoefficients
ThinkGeo.MapSuite.Core.EmpiricalFunctionCoefficients
Class EmpiricalFunctionCoefficients.
    • ThinkGeo.MapSuite.Core.EmpiricalFunctionCoefficients
EmpiricalFunctionCoefficients()
  • Initializes a new instance of the class.
EmpiricalFunctionCoefficients(Double,Double,Double)
  • range
    • Description:The range.
  • sill
    • Description:The sill.
  • nugget
    • Description:The nugget.
Range
  • Gets or sets the distance(x-axis) where the empirical function first flattens.
Nugget
  • Gets or sets the value of crossing point with empirical function and semivariance(y-axis).
Sill
  • Gets or sets the value at which the semivariance(y-axis) attains the coefficients of Range.
thinkgeo.mapsuite.portablecore.empiricalfunctioncoefficients.txt · Last modified: 2017/03/16 21:59 (external edit)
