thinkgeo.mapsuite.portablecore.drawinglinecap
ThinkGeo.MapSuite.Core.DrawingLineCap
  • This enumeration represents the available cap styles with which a GeoPen object can end a line.
  • None
Items
Flat
  • Summary:This member specifies a flat line cap.
AnchorMask
  • Summary:This member specifies a mask used to check whether a line cap is an anchor cap.
ArrowAnchor
  • Summary:This member specifies an arrow-shaped anchor cap.
Custom
  • Summary:This member specifies a custom line cap.
DiamondAnchor
  • Summary:This member specifies a diamond anchor cap.
Round
  • Summary:This member specifies a round line cap.
NoAnchor
  • Summary:This member specifies no anchor.
RoundAnchor
  • Summary:This member specifies a round anchor cap.
Square
  • Summary:This member specifies a square line cap.
SquareAnchor
  • Summary:This member specifies a square anchor line cap.
Triangle
  • Summary:This member specifies a triangular line cap.
thinkgeo.mapsuite.portablecore.drawinglinecap.txt · Last modified: 2017/03/16 21:59 (external edit)
