thinkgeo.mapsuite.portablecore.degreesminutesseconds
ThinkGeo.MapSuite.PortableCore.DegreesMinutesSeconds
<!– Structure –> This structure represents a degrees, minutes and seconds value.
This structure is used in many places to represent decimal degree numbers as degrees, minutes and seconds.
Public MethodDegreesMinutesSeconds Int32, Int32, Double This constructor allows you to create an instance of the class by specifying the degree, minute and second values.
Public MethodAdd DegreesMinutesSeconds Add two DegreesMinutsSeconds together and return back a summary of the two.
Public MethodEquals Object Object(overriden) Compares current DegreesMinutesSeconds with a passing object.
Public MethodGetHashCode Object(overriden) Serves as hash function for the particular type.
Public MethodGetType Object
Public MethodToString Object(overriden) This method returns a formatted representation of the degrees, minutes and seconds value.
Public MethodToString Int32 This method returns a formatted representation of the degrees, minutes and seconds value that has been rounded to the specified decimals.
Public PropertyDegrees Int32 This property returns the degrees portion of the structure.
Public PropertyMinutes Int32 This property returns the minutes portion of the structure.
Public PropertySeconds Double This property returns the seconds portion of the structure.
DegreesMinutesSeconds(Int32, Int32, Double)
Name Type Description
degrees Int32<!– System.Int32 –> This parameter represents the degree portion of the structure.
minutes Int32<!– System.Int32 –> This parameter represents the minute portion of the structure.
seconds Double<!– System.Double –> This parameter represents the second portion of the structure.
Go Back
Add(DegreesMinutesSeconds)
Return Type Description
DegreesMinutesSeconds<!– ThinkGeo.MapSuite.PortableCore.DegreesMinutesSeconds –> The summary of the two DegreesMinutesSeconds.
targetDegreesMinutesSeconds DegreesMinutesSeconds<!– ThinkGeo.MapSuite.PortableCore.DegreesMinutesSeconds –> The target DegreesMinutesSeconds to be added together.
<!– ThinkGeo.MapSuite.PortableCore.DegreesMinutesSeconds –> Go Back
Boolean<!– System.Boolean –> True if the passing object satisfies the following two conditions:1) The object is of DegreesMinutesSeconds type.2) The Degrees, Minutes and Seconds of both DegreesMinutesSeconds should be the same.If both conditions are not met, will return false.
obj Object<!– System.Object –> The passing object which will be used to compare with current DegreesMinutesSeconds.
Int32<!– System.Int32 –> The hash code for this particular type.
Type<!– System.Type –>
The value will be formatted in the standard string format: 75º 21' 28“
String<!– System.String –> This method returns a formatted representation of the degrees, minutes and seconds value.
ToString(Int32)
The value will be formatted in the standard string format. For example, 75º 21' 2.1235” (when the decimals parameter is set to 4).
decimals Int32<!– System.Int32 –> The target decimals that the degrees, minutes, seconds value will be rounded to.
Void<!– System.Void –>
Degrees
Return Type
Minutes
Return Type
Seconds
Return Type
thinkgeo.mapsuite.portablecore.degreesminutesseconds.1440040132.txt.gz · Last modified: 2015/09/21 08:06 (external edit)
