thinkgeo.mapsuite.portablecore.dbflinkrecords
ThinkGeo.MapSuite.Core.DbfLinkRecords
    • ThinkGeo.MapSuite.Core.LinkRecords
      • ThinkGeo.MapSuite.Core.DbfLinkRecords
DbfLinkRecords()
DbfLinkRecords(String)
  • pathFilename
DbfLinkRecords(String,String)
  • pathFilename
  • name
Open()
Close()
Dispose()
GetColumns()
GetColumnValues(Int32,IEnumerable<String>)
  • Type:Dictionary<String,Object>
  • recordIndex
  • returningColumnNames
    • Type:IEnumerable<String>
MoveNext()
Reset()
GetEnumerator()
GetCurrentRecordCore()
OpenCore()
CloseCore()
MoveNextCore()
GetColumnsCore()
GetColumnValuesCore(Int32,IEnumerable<String>)
  • recordIndex
  • columnNames
DisposeCore()
GetCurrentRecord()
ResetCore()
PathFilename
ColumnNamesToExclude
  • Type:Collection<String>
Current
IsCacheEnabled
IsOpen
RequiredColumnNames
ReturningColumnNames
Position
ChY=
thinkgeo.mapsuite.portablecore.dbflinkrecords.txt · Last modified: 2017/03/16 21:59 (external edit)
