<!– Class –> This class formats a GeoObjectModel into C# code.
*System.Object ThinkGeo.MapSuite.PortableCore.GeoCodeFormatter *ThinkGeo.MapSuite.PortableCore.CSharpGeoCodeFormatter
CSharpGeoCodeFormatter | Creates an instance of CSharpGeoCodeFormatter. |
Save | GeoObjectModel, Stream | GeoCodeFormatter | Creates code for a GeoObjectModel and save the code into a Stream. |
MemberwiseClone | Object | ||
SaveCore | GeoObjectModel, Stream | GeoCodeFormatter(overriden) | Creates C# code for a GeoObjectModel and save the code into a Stream. |
| model | GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel to generate code for. |
| stream | Stream<!– System.IO.Stream –> | The Stream to save code into. |
<!– ThinkGeo.MapSuite.PortableCore.GeoCodeFormatter –> Go Back
| model | GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The GeoObjectModel to generate C# code for. |
| stream | Stream<!– System.IO.Stream –> | The Stream to save C# code into. |
<!– ThinkGeo.MapSuite.PortableCore.GeoCodeFormatter(overriden) –> Go Back
