<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.Style *ThinkGeo.MapSuite.PortableCore.PointBaseStyle ThinkGeo.MapSuite.PortableCore.PointStyle *ThinkGeo.MapSuite.PortableCore.ClusterPointStyle
![]() | GeoImage | ||
![]() | GeoFont, Int32, GeoSolidBrush | ||
![]() | PointSymbolType, GeoSolidBrush, Int32 | ||
![]() | PointSymbolType, GeoSolidBrush, GeoPen, Int32 |
![]() | Style | Create a copy of style using the deep clone process. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
![]() | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
![]() | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
![]() | GeoCanvas | Style | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object | ||
![]() | Object |
![]() | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | |
![]() | GeoCanvas, DrawingRectangleF | Style(overriden) | |
![]() | Object | ||
![]() | Object |
![]() | PointStyleAdvanced | PointBaseStyle | |
![]() | Int32 | ||
![]() | GeoFont | PointStyle | This property gets and sets the font that is used for the character if the PointType is Character. |
![]() | Int32 | PointStyle | This property gets and sets the index position of the character you want to use from the font you selected in the CharacterFont property. |
![]() | GeoSolidBrush | PointStyle | This property gets and sets the SolidBrush used to color the font character for the point. |
![]() | Collection<PointBaseStyle> | PointBaseStyle | This property returns a collection of area styles allowing you to stack multiple area styles on top of each other. |
![]() | DrawingLevel | PointBaseStyle | |
![]() | Collection<String> | Style | |
![]() | GeoImage | PointStyle | This property gets and sets the image used if the PointType property is NativeImage. |
![]() | Double | PointStyle | This property gets and sets the scale of the image you want to draw. |
![]() | Boolean | Style | This property gets and sets the active status of the style. |
![]() | String | Style | This property gets and set the name of the style. |
![]() | PointType | PointStyle | This property gets and sets the type of point you want to draw. |
![]() | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
![]() | Single | PointBaseStyle | This property gets and sets the angle of rotation for the drawing of the point. |
![]() | GeoPen | PointBaseStyle | This property gets and sets the SolidBrush used to draw the oultine of the Symbol. |
![]() | Single | PointBaseStyle | This property gets and sets the size of the symbol if the PointType is Symbol. |
![]() | GeoSolidBrush | PointBaseStyle | This property gets and sets the SolidBrush used to color the interior of the Symbol. |
![]() | PointSymbolType | PointStyle | This property gets and sets the type of symbol you want to use if the PointType is Symbol. |
![]() | TextStyle | ||
![]() | Single | PointBaseStyle | This property gets and sets the X pixel offset for drawing each feature. |
![]() | Single | PointBaseStyle | This property gets and sets the Y pixel offset for drawing each feature. |
Name | Type | Description |
characterFont | GeoFont<!– ThinkGeo.MapSuite.PortableCore.GeoFont –> | |
characterIndex | Int32<!– System.Int32 –> | |
characterSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.PortableCore.GeoSolidBrush –> |
symbolType | PointSymbolType<!– ThinkGeo.MapSuite.PortableCore.PointSymbolType –> | |
symbolSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.PortableCore.GeoSolidBrush –> | |
symbolSize | Int32<!– System.Int32 –> |
symbolPen | GeoPen<!– ThinkGeo.MapSuite.PortableCore.GeoPen –> | |
Return Type | Description |
Style<!– ThinkGeo.MapSuite.PortableCore.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.PortableCore.Style –> Go Back
Void<!– System.Void –> |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.PortableCore.DrawingRectangleF –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
Type<!– System.Type –> |
String<!– System.String –> |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Feature} –> | |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Style(overriden) –> Go Back
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Return Type |
PointStyleAdvanced<!– ThinkGeo.MapSuite.PortableCore.PointStyleAdvanced –> |
<!– ThinkGeo.MapSuite.PortableCore.PointBaseStyle –> Go Back
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.ClusterPointStyle –> Go Back
This property allows you to set the font from which to select a character index if you choose the Character PointType.
Return Type |
<!– ThinkGeo.MapSuite.PortableCore.PointStyle –> Go Back
You need to specify the index position of the character you want to use from the font you selected. For example, if you choose 1, then we will use the first character in the font you set in the CharacterFont property.
Return Type |
This brush is used to draw the character. It is only used if the PointType is Character. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
Return Type |
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
Return Type |
Collection<PointBaseStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.PointBaseStyle} –> |
Return Type |
DrawingLevel<!– ThinkGeo.MapSuite.PortableCore.DrawingLevel –> |
Return Type |
This property is where you can set the image for the points if the PointType is NativeImage. It uses a GeoImage, so you can either reference a file or supply a stream.
Return Type |
GeoImage<!– ThinkGeo.MapSuite.PortableCore.GeoImage –> |
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
Return Type |
Double<!– System.Double –> |
Return Type |
Return Type |
When using the PointStyle you choose between a bitmap, a font or a predefined symbol to represent the point. Each of these options has corresponding properties on the point symbol. If you set the type to character, then you need to set the properties that start with “Character,” such as “CharacterFont.” The same is true for the symbol.
Return Type |
PointType<!– ThinkGeo.MapSuite.PortableCore.PointType –> |
Return Type |
This property controls the rotation of the bitmap, character or symbol, depending on the PointType.
Return Type |
Single<!– System.Single –> |
This pen is used to draw the outline of the Symbol. By default the pen draws a transparent (invisible) color, which just leaves you with a fill.
Return Type |
The allows you to make the symbol larger and smaller.
Return Type |
This brush is used to draw the interior of the symbol. It is only used if the PointType is Symbol. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
Return Type |
You can choose between a number of predefined symbols. The symbols are simple geometric objects that are typically used for abstract representations on a map. If there is a specific symbol you need that is not part of our symbol collection, you can submit it to us and we will consider adding it.
Return Type |
Return Type |
TextStyle<!– ThinkGeo.MapSuite.PortableCore.TextStyle –> |
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type |
This property allows you to specify a Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type |
Return Type |
