thinkgeo.mapsuite.portablecore.backgroundlayer
ThinkGeo.MapSuite.Core.BackgroundLayer
This class draws the background of the map.
      • ThinkGeo.MapSuite.Core.BackgroundLayer
BackgroundLayer()
  • This is the default constructor for the class.
BackgroundLayer(GeoBrush)
  • None
  • backgroundBrush
    • Type:GeoBrush
    • Description:This parameter is the brush that will be used draw the background layer.
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • This method will draw the background layer based on the parameters provided.
  • None
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the GeoCanvas used to Draw the layer.
  • labelsInAllLayers
    • Description:This parameter is not used for BackgroundLayers.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
OpenCore()
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
BackgroundBrush
  • This property gets and sets the brush for this background layer.
  • None
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
IsOpenCore
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.backgroundlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
