thinkgeo.mapsuite.portablecore.adornmentlayersdrawingeventargs
ThinkGeo.MapSuite.PortableCore.AdornmentLayersDrawingEventArgs
<!– Class –> This is the event arguments class for the AdornmentLayersDrawing event. It is raised before any of the AdornmentLayers are drawn.
This is the event arguments class for the AdornmentLayersDrawing event. It is raised before any of the AdornmentLayers are drawn. This event allows you to manipulate the AdornmentLayers, or draw something with the canvas before any of the AdornmentLayers are drawn.
Public MethodAdornmentLayersDrawingEventArgs This is the default constructor for the class.
Public MethodAdornmentLayersDrawingEventArgs IEnumerable<AdornmentLayer> This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyAdornmentLayers IEnumerable<AdornmentLayer> This property gets and sets the AdornmentLayers that will be drawn.
AdornmentLayersDrawingEventArgs()
Overloads
Name Type Description
Go Back
AdornmentLayersDrawingEventArgs(IEnumerable<AdornmentLayer>)
adornmentLayers IEnumerable<AdornmentLayer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.AdornmentLayer} –> This parameter is the AdornmentLayers that will be drawn.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
AdornmentLayers
Return Type
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayersDrawingEventArgs –> Go Back
thinkgeo.mapsuite.portablecore.adornmentlayersdrawingeventargs.1440040132.txt.gz · Last modified: 2015/09/21 08:03 (external edit)
