thinkgeo.mapsuite.portablecore.adornmentlayerdrawingeventargs
ThinkGeo.MapSuite.Core.AdornmentLayerDrawingEventArgs
      • ThinkGeo.MapSuite.Core.AdornmentLayerDrawingEventArgs
AdornmentLayerDrawingEventArgs()
  • This is the default constructor for the class.
AdornmentLayerDrawingEventArgs(AdornmentLayer)
  • None
  • adornmentLayer
    • Description:This parameter is the AdornmentLayer that will be drawn.
AdornmentLayer
  • This property gets and sets the AdornmentLayer that will be drawn.
  • None
thinkgeo.mapsuite.portablecore.adornmentlayerdrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
