<!– Class –>
*System.Object **ThinkGeo.MapSuite.Portable.PortableFile
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | String, String, Boolean | ||
![]() | String | ||
![]() | String | ||
![]() | String | ||
![]() | Object | ||
![]() | String | ||
![]() | String | ||
![]() | Object | ||
![]() | String, String | ||
![]() | String, GeoFileMode, GeoFileAccess, GeoFileShare | ||
![]() | String, GeoFileMode, GeoFileAccess | ||
![]() | String | ||
![]() | String | ||
![]() | String | ||
![]() | String | ||
![]() | String, Int32 | ||
![]() | String, DateTime | ||
![]() | String, Byte[] | ||
![]() | String, String[] |
Name | Type | Description |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
sourceFileName | String<!– System.String –> | |
destFileName | String<!– System.String –> | |
overwrite | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.Portable.PortableFile –> Go Back
Stream<!– System.IO.Stream –> |
path | String<!– System.String –> |
filename | String<!– System.String –> |
DateTime<!– System.DateTime –> |
path | String<!– System.String –> | |
mode | GeoFileMode<!– ThinkGeo.MapSuite.Core.GeoFileMode –> | |
access | GeoFileAccess<!– ThinkGeo.MapSuite.Core.GeoFileAccess –> | |
share | GeoFileShare<!– ThinkGeo.MapSuite.Core.GeoFileShare –> |
Byte[]<!– System.Bytethinkgeo.mapsuite.portable.portablefile –> |
String[]<!– System.Stringthinkgeo.mapsuite.portable.portablefile –> |
fileAttributes | Int32<!– System.Int32 –> |
filename | String<!– System.String –> | |
dateTime | DateTime<!– System.DateTime –> |
fileName | String<!– System.String –> | |
bytes | Byte[]<!– System.Bytethinkgeo.mapsuite.portable.portablefile –> |
lines | String[]<!– System.Stringthinkgeo.mapsuite.portable.portablefile –> |
