<!– Class –> Represents a small image that displays on the map.
The <strong>WebImage</strong> object represents a small image on the map. The <strong>WebImage</strong> class has many properties that determine the apprearance of the image. Currently, the WebImage is used for creating markers.
*System.Object **ThinkGeo.MapSuite.MvcEdition.WebImage
WebImage | Initialize a new instance of the WebImage class. | ||
WebImage | String | Initialize a new instance of the WebImage class. | |
WebImage | Int32, Int32 | Initialize a new instance of the WebImage class. | |
WebImage | Int32, Int32, Single, Single | Initialize a new instance of the WebImage class. | |
WebImage | String, Int32, Int32 | Initialize a new instance of the WebImage class. | |
WebImage | String, Int32, Int32, Single, Single | Initialize a new instance of the WebImage class. |
CloneShallow | Creates a shallow copy of the current WebImage object. | ||
FromJson | String | ||
ToJson | Returns a JSON string that contains the information for creating a client image object at the client side. | ||
FontColor | GeoColor | Gets or sets the color of the text on the image. | |
FontStyle | GeoFont | Gets or sets the style applied to the text on the image. | |
ImageHeight | Int32 | Gets or sets the height of the web image. | |
ImageOffsetX | Single | Gets or sets the image's X offset. | |
ImageOffsetY | Single | Gets or sets the image's Y offset. | |
ImageVirtualPath | String | Gets or sets the virtual path of the image file. | |
ImageWidth | Int32 | Gets or sets the width of the web image. | |
RotationAngle | Single | Gets or sets the rotation angle of the web image. | |
Text | String | Gets or sets the text displayed on the image. | |
TextBackgroundColor | GeoColor | Gets or sets the background color of the text on the image. | |
TextOffsetX | Single | Gets or sets the X offset of the text on the image. | |
TextOffsetY | Single | Gets or sets the Y offset of the text on the image. |
| imageVirtualPath | String<!– System.String –> | The virtual path of the image. |
| imageWidth | Int32<!– System.Int32 –> | The width of the image. |
| imageHeight | Int32<!– System.Int32 –> | The height of the image. |
| imageOffsetX | Single<!– System.Single –> | The offset X of the image. |
| imageOffsetY | Single<!– System.Single –> | The offset Y of the image. |
| WebImage<!– ThinkGeo.MapSuite.MvcEdition.WebImage –> |
<!– ThinkGeo.MapSuite.MvcEdition.WebImage –> Go Back
| jsonString | String<!– System.String –> |
| String<!– System.String –> | A JSON string that contains the information for creating a client image object at the client side. |
| GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> |
| GeoFont<!– ThinkGeo.MapSuite.Core.GeoFont –> |
