thinkgeo.mapsuite.mvcedition.singlethreadtileresource
ThinkGeo.MapSuite.MvcEdition.SingleThreadTileResource
<!– Class –> This is an asynchronous HTTP handler which is used to handle web map services.
Public MethodSingleThreadTileResource This is the default constructor for the TileResourceSingleThread class.
Public MethodGetType Object
Public MethodProcessRequest HttpContext Enables processing of HTTP Web requests by a custom HttpHandler.
Public MethodToString Object
Protected MethodProcessRequestCore HttpContext Enables processing of HTTP Web requests by a custom HttpHandler.
Public PropertyIsReusable Boolean Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance.
SingleThreadTileResource()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
ProcessRequest(HttpContext)
Void<!– System.Void –>
context HttpContext<!– System.Web.HttpContext –> A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
<!– ThinkGeo.MapSuite.MvcEdition.SingleThreadTileResource –> Go Back
String<!– System.String –>
ProcessRequestCore(HttpContext)
IsReusable
Return Type
thinkgeo.mapsuite.mvcedition.singlethreadtileresource.1440040131.txt.gz · Last modified: 2015/09/21 03:35 (external edit)
