thinkgeo.mapsuite.mvcedition.panzoommaptool
ThinkGeo.MapSuite.MvcEdition.PanZoomMapTool
<!– Class –> Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
The PanZoom map tool contains a panning control and two zooming (in/out) buttons. The panning controls have four panning buttons and a globe button that zooms the map out to show the whole world. Set the <strong>Enabled</strong> property to true to show this tool on the map.
Public MethodPanZoomMapTool Initialize an instance of the PanZoomMapTool class.
Public MethodFromJson String MapTool Load this object from a json string.
Public MethodGetType Object
Public MethodToJson MapTool Returns a JSON string that represents the map control object.
Public MethodToString Object
Public PropertyEnabled Boolean MapTool Gets or sets a value that turns the feature on and off.
Public PropertyIsGlobeButtonEnabled Boolean Gets or sets a boolean value that determines whether the globe button shows in the PanZoom map tool.
PanZoomMapTool()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> A JSON string that represents the map control.
Enabled
Return Type
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.PanZoomMapTool –> Go Back
thinkgeo.mapsuite.mvcedition.panzoommaptool.1440040131.txt.gz · Last modified: 2015/09/21 03:35 (external edit)
