thinkgeo.mapsuite.mvcedition.overlayswitchermaptoolsetting
ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting
<!– Class –> A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
*System.Object
  • PublicKeyToken=null]]
    • Culture=neutral
      • Version=9.0.0.0
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool **ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting
Public MethodOverlaySwitcherMapToolSetting OverlaySwitcherMapTool Initializes a new instance of the OverlaySwitcherMapToolSetting class.
Public MethodBackgroundColor GeoColor Set backgroundColor for Element property and retun the OverlaySwitcherMapToolSetting
Public MethodBaseOverlayTitle String Set baseOverlayTitle for Element property and retun the OverlaySwitcherMapToolSetting
Public MethodDynamicOverlayTitle String Set dynamicOverlayTitle for Element property and retun the OverlaySwitcherMapToolSetting
Public MethodEnabled Boolean MapToolSetting<OverlaySwitcherMapTool,OverlaySwitcherMapToolSetting>
Public MethodGetType Object
Public MethodOnClientBaseOverlayChanged String Set onClientBaseOverlayChanged javascript function name for Element property and retun the OverlaySwitcherMapToolSetting
Public MethodRoundedCornerColor GeoColor Set roundedCornerColor for Element property and retun the OverlaySwitcherMapToolSetting
Public MethodToString Object
OverlaySwitcherMapToolSetting(OverlaySwitcherMapTool)
Name Type Description
mapTool OverlaySwitcherMapTool<!– ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool –>
Go Back
BackgroundColor(GeoColor)
Return Type Description
OverlaySwitcherMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting –> The setting of OverlaySwitcherMapToolSetting itself
backgroundColor GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> A backgroundColor for Element property
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting –> Go Back
BaseOverlayTitle(String)
baseOverlayTitle String<!– System.String –> A baseOverlayTitle for Element property
DynamicOverlayTitle(String)
dynamicOverlayTitle String<!– System.String –> A dynamicOverlayTitle for Element property
Enabled(Boolean)
isEnabled Boolean<!– System.Boolean –>
<!– ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool,ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting} –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
OnClientBaseOverlayChanged(String)
onClientBaseOverlayChanged String<!– System.String –> A onClientBaseOverlayChanged javascript function name for Element property
RoundedCornerColor(GeoColor)
roundedCornerColor GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> A roundedCornerColor for Element property
Void<!– System.Void –>
Element
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool,ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.overlayswitchermaptoolsetting.1440040131.txt.gz · Last modified: 2015/09/21 03:35 (external edit)
