thinkgeo.mapsuite.mvcedition.openstreetmapoverlaysetting
ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting
<!– Class –> A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
*System.Object
  • PublicKeyToken=null]]
    • Culture=neutral
      • Version=9.0.0.0
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlay PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlay **ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting
Public MethodOpenStreetMapOverlaySetting OpenStreetMapOverlay Initializes a new instance of the OpenStreetMapOverlaySetting class.
OpenStreetMapOverlaySetting(OpenStreetMapOverlay)
Name Type Description
openStreetMapOverlay OpenStreetMapOverlay<!– ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlay –>
Go Back
AutoRefreshInterval(TimeSpan)
Return Type Description
OpenStreetMapOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting –>
timeSpan TimeSpan<!– System.TimeSpan –>
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlay,ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting} –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Id(String)
id String<!– System.String –>
IsBaseOverlay(Boolean)
isBaseOverlay Boolean<!– System.Boolean –>
IsVisible(Boolean)
isVisible Boolean<!– System.Boolean –>
IsVisibleInOverlaySwitcher(Boolean)
isVisibleInOverlaySwitcher Boolean<!– System.Boolean –>
Name(String)
name String<!– System.String –>
OnClientAutoRefreshTick(String)
clientTickFunctionName String<!– System.String –>
Opacity(Single)
opacity Single<!– System.Single –>
TileHeight(Int32)
Set tileHeight for Element property and retun the OpenStreetMapOverlaySetting
OpenStreetMapOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting –> The setting of OpenStreetMapOverlaySetting itself
tileHeight Int32<!– System.Int32 –> A tileHeight for Element property
<!– ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting –> Go Back
TileWidth(Int32)
Set tileWidth for Element property and retun the OpenStreetMapOverlaySetting
tileWidth Int32<!– System.Int32 –> A tileWidth for Element property
Void<!– System.Void –>
Element
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlay,ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting} –> Go Back
thinkgeo.mapsuite.mvcedition.openstreetmapoverlaysetting.1440040131.txt.gz · Last modified: 2015/09/21 03:35 (external edit)
