thinkgeo.mapsuite.mvcedition.mvcelementsettingbase_2
ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase<TElement,TSetting>
This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
    • ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase<TElement,TSetting>
MvcElementSettingBase`2()
  • Initializes a new instance of MvcElementSettingBase.
MvcElementSettingBase`2(TElement)
  • mapElement
    • Type:TElement
Element
Gets the element.
  • Type:TElement
thinkgeo.mapsuite.mvcedition.mvcelementsettingbase_2.txt · Last modified: 2017/03/16 21:59 (external edit)
