<!– Class –> This is an asynchronous HTTP handler which is used to handle web map services.
*System.Object **ThinkGeo.MapSuite.MvcEdition.MultiThreadTileResource
![]() | This is the default constructor for the TileResource class. |
![]() | HttpContext, AsyncCallback, Object | Initiates an asynchronous call to the HTTP handler. | |
![]() | IAsyncResult | Provides an asynchronous process End method when the process ends. | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | HttpContext | Enables processing of HTTP Web requests by a custom HttpHandler. | |
![]() | Object |
![]() | Object | ||
![]() | Object | ||
![]() | Boolean | Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance. |
Name | Type | Description |
Return Type | Description |
IAsyncResult<!– System.IAsyncResult –> | A System.IAsyncResult that contains information about the status of the process. |
context | HttpContext<!– System.Web.HttpContext –> | A System.Web.HttpContext object that provides references to intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. |
cb | AsyncCallback<!– System.AsyncCallback –> | The System.AsyncCallback to call when the asynchronous method call is complete. If cb is null, the delegate is not called. |
extraData | Object<!– System.Object –> | Any extra data needed to process the request. |
<!– ThinkGeo.MapSuite.MvcEdition.MultiThreadTileResource –> Go Back
Void<!– System.Void –> |
result | IAsyncResult<!– System.IAsyncResult –> | A System.IAsyncResult that contains information about the status of the process. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
context | HttpContext<!– System.Web.HttpContext –> | A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. |
String<!– System.String –> |
Return Type |
