thinkgeo.mapsuite.mvcedition.markerstylesetting_tmarkerstyle_tsetting
ThinkGeo.MapSuite.MvcEdition.MarkerStyleSetting‹TMarkerStyle,_TSetting›
<!– Class –> A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
Public MethodMarkerStyleSetting‹TMarkerStyle, TSetting› TMarkerStyle
Protected MethodMarkerStyleSetting‹TMarkerStyle, TSetting› Initializes a new instance of the MarkerStyleSetting class.
Public MethodGetType Object
Public MethodToString Object
Protected PropertyElement TMarkerStyle MvcElementSettingBase<TMarkerStyle,TMarkerStyleSetting>
MarkerStyleSetting‹TMarkerStyle, TSetting›(TMarkerStyle)
Name Type Description
style TMarkerStyle<!– TMarkerStyle –>
Go Back
MarkerStyleSetting‹TMarkerStyle, TSetting›()
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Element
Return Type
<!– MvcElementSettingBase{TMarkerStyle,TMarkerStyleSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.markerstylesetting_tmarkerstyle_tsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
