thinkgeo.mapsuite.mvcedition.maptoolsetting_2
ThinkGeo.MapSuite.MvcEdition.MapToolSetting<TMapTool,TSetting>
A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
    • ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase<TMapTool,TSetting>
      • ThinkGeo.MapSuite.MvcEdition.MapToolSetting<TMapTool,TSetting>
MapToolSetting`2()
  • Initializes a new instance of the MapToolSetting class.
MapToolSetting`2(TMapTool)
  • mapTool
    • Type:TMapTool
Enabled(Boolean)
  • Set isEnabled for Element property and retun the MapToolSetting
  • Type:TSetting
  • Description:The setting of MapToolSetting itself
  • isEnabled
    • Description:A boolean variable for Element property represent the setting is enable or not
Element
  • Type:TMapTool
thinkgeo.mapsuite.mvcedition.maptoolsetting_2.txt · Last modified: 2017/03/16 21:59 (external edit)
