thinkgeo.mapsuite.mvcedition.georesourcefactory
ThinkGeo.MapSuite.MvcEdition.GeoResourceFactory
<!– Class –>
Public MethodGeoResourceFactory
Public MethodGetHandler HttpContext, String, String, String Returns an instance of a class that implements the System.Web.IHttpHandler interface.
Public MethodGetType Object
Public MethodReleaseHandler IHttpHandler Enables a factory to reuse an existing handler instance.
Public MethodToString Object
Protected MethodGetHandlerCore HttpContext Returns an instance of a class that implements the System.Web.IHttpHandler interface.
GeoResourceFactory()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetHandler(HttpContext, String, String, String)
IHttpHandler<!– System.Web.IHttpHandler –> A new System.Web.IHttpHandler object that processes the request.
context HttpContext<!– System.Web.HttpContext –> An instance of the System.Web.HttpContext class that provides references to intrinsic server objects (for example, Request, Response, Session, and Server) used to service HTTP requests.
requestType String<!– System.String –> The HTTP data transfer method (GET or POST) that the client uses.
url String<!– System.String –> The System.Web.HttpRequest.RawUrl of the requested resource.
pathTranslated String<!– System.String –> The System.Web.HttpRequest.PhysicalApplicationPath to the requested resource.
<!– ThinkGeo.MapSuite.MvcEdition.GeoResourceFactory –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ReleaseHandler(IHttpHandler)
Void<!– System.Void –>
handler IHttpHandler<!– System.Web.IHttpHandler –> The System.Web.IHttpHandler object to reuse.
GetHandlerCore(HttpContext)
thinkgeo.mapsuite.mvcedition.georesourcefactory.1440040131.txt.gz · Last modified: 2015/09/21 03:33 (external edit)
